isspro fuel
Old Aug 31, 2008 | 09:06 AM
turbo246's Avatar
isspro fuel
i just bought this kit http://www.vulcanperformance.com/ser...-30-PSI/Detail and am goin to put it in my 01. I dont believe it came with a tapped banjo so I will have to order one, but I am going to go from the test port on the injector pump. I take the plug thats in there out and put the bajo bolt there correct? then just run the line to my needle valve and isolator if i use it then to the gauge? this sound right>
Old Aug 31, 2008 | 09:11 AM
mishkaya's Avatar
If you are going to use a tapped banjo bolt, I would suggest the outlet of the fuel filter instead. First because it's a shorter run that way and also because you won't have the vibrations as bad either from the injection pump.
mishkaya
Chopper_Bob
13
Jan 10, 2007 09:54 AM
CRXsi
21
Jan 13, 2006 09:38 AM
Gunmetal
Apr 1, 2005 10:07 AM
deezulsmoke
0
Mar 21, 2005 09:59 PM
Dodgezilla
Mar 7, 2003 12:06 PM
