Intercooler boots
Old Jul 24, 2007 | 06:52 PM
allisfarmer's Avatar
crap,....i just bought some BD boots
Old Jul 24, 2007 | 07:01 PM
Tiger Rag's Avatar
How much boost are you running? Under 50, I'd say you're fine. I can get up to 60 or so with my twins and mine hold....except for that one time. At least they're easy to install. I think BD advertises that they're supposed to be good for 70psi....."not so fast my friend"....I don't buy that at this point, especially since I rarely get above 50. I think it was a little above 50 when it popped. TST was only on 1 or 2, can't remember.
Old Jul 27, 2007 | 10:00 AM
stylinMotors's Avatar
Muted User
Originally Posted by Hammer
IF your running a big charger save yourself the headaches and buy the ones from PDR.With silicone boots they are way to easy to blow and I have seen the Stylin Motors and B-D Power boots come apart under a heavy dyno rip.
When have you seen ours come apart? We just came out with these kits, before release we tested to 120 psi, with no problems. The ones at PDR are Silicone as well. Do not know about the ones from B-D. We offer full warranty on ours.
Old Jul 27, 2007 | 11:11 AM
olddodgetruck's Avatar
it your right in mass i would give scott a call at mass diesel thats where i got my pdr boots.
Old Jul 27, 2007 | 05:36 PM
Dshiftff's Avatar
Doug, PDR, Period.
Old Jul 27, 2007 | 08:02 PM
tony597fitter's Avatar
Doug, stylinmotors, period
Old Jul 27, 2007 | 10:49 PM
aurora 5000 air probably over 50lbs....oh well that will teach me not to research something first
Old Jul 27, 2007 | 11:56 PM
Muted User
Not following you there.
Old Jul 28, 2007 | 04:08 PM
bent valves's Avatar
Don't give up on the BD boots.
I swapped out the stock boots to the BD ones when the twins went on. The BD boots and many others come with spring-loaded clamps but no instructions on how tight to crank the springs down. I had assumed the purpose of the spring was to keep a constant pressure on the boot but I was wrong. It sounded like a ¼ stick of dynamite going off when the boot let go at around 50 psi. I then experimented with a torque wrench and found the spring will just stack tight at about 25 inch pounds. I increased the torque to 35 inch pounds and drove around making about 50 psi of boost and found the BD boot had started to slip out from under the clamp. The final solution for me was to get rid of the springs and retrofit an aluminum spacer. The springs only seem to make it harder to take a clamp on or off. After the spring delete, I greased and torqued the boots to 100 inch pounds. This solved my problems with the boots.
Old Jul 28, 2007 | 05:06 PM
bob4x4's Avatar
Greased the boots???
Bob
Old Jul 28, 2007 | 05:10 PM
duner's Avatar
so if the bd's blow and they won't warranty them if you accidentally install their funky clamps wrong because they don't supply instructions then i won't and i can only suggest nobody else buys them. anyway that's what i got from all this.
Old Jul 28, 2007 | 05:30 PM
Doh. I should have said that I greased the bolts not boots. But it’s not a bad idea for the fourth of July.
Old Aug 1, 2007 | 06:32 AM
redneck_racer's Avatar
Go to turbohoses.com thats the cheapest i have found when I started blowing my hoses and since ive replaced it No problems 40 PSI of boost and still strong.
Old Aug 1, 2007 | 07:57 AM
Mike D's Avatar
I'm still running stock boots at 138,000 miles w/nitrous...
Old Oct 22, 2008 | 08:12 PM
feveree40's Avatar
At work we tighten those contant torque hose clamps on boost tubes to 110 in/lb.
