Installing Tranny Guage???
Old Oct 28, 2003 | 04:31 PM
GreyBoy's Avatar
How do I install the tranny guage sensor??? I noticed on the back of the guage, there are three screw downs marked +, -, and S. Which one do I hook the wire from the sensor to???
BTW 98 Auto (47RE I believe, but might be 47RH ???)
Thanks,
Sam
Old Oct 28, 2003 | 04:35 PM
MLR1's Avatar
Re:Installing Tranny Guage???
Sender goes to the terminal labeled s, switched 12v to +, ground to -.
Old Oct 28, 2003 | 05:11 PM
GreyBoy's Avatar
What do you mean by switched 12v???
Old Oct 28, 2003 | 05:14 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Only hot with the Key (switch) on.
Old Oct 28, 2003 | 05:18 PM
GreyBoy's Avatar
OH!! Thanks!!!
Old Oct 28, 2003 | 05:55 PM
VinDiesel's Avatar
BTW, it's common to have a threaded hole in an aftermarket trans pan to put the sender in (the way I currently have mine). That will only give you the oil temp after the cooler.
Many (including myself) consider it more useful to have the sender in the line going to the cooler/heat exchanger to get a better idea of the actual temp coming off the bands and clutches. This requires a little more plumbing (either a compression tee as described in a past thread, or a line with the fitting already there, i.e.- earlier model or aftermarket).
atch
Jun 22, 2005 07:43 AM
betsycam
Sep 9, 2004 02:13 PM
betsycam
19
Aug 19, 2004 08:30 AM
dkinzer
Oct 2, 2003 01:15 AM
cLAYH
Aug 27, 2003 01:50 AM
