installing gauges ???'s
Old Jun 4, 2005 | 10:02 AM
getblown5.9's Avatar
First gauge is the trans temp. I have the NV5600 6spd manual and it had FAST coolers previously installed. From what i read the cooler should have a plug ready for a sending unti to be put right in...my question is more along the lines of should i go ahead and drain and change the fluid when i do the sending unit install? I was thinking of going to a better quality trans fluid. What do you guys recommend?
Next is the new mechanical boost gauge. Its an autometer 0-60 psi...and im not sure where i can pick up a vacuum/boost line for the plastic tubing to run to the guage...where do you guys have your mech gauges connected?
and lastly...does anyone make a pod that sits on the dash of a 2nd gen for 3- 2-5/8" guages...ive heard of them before...but dont know where to find them. Thanks for all your help folks!
Old Jun 4, 2005 | 10:27 AM
pmtg's Avatar
trans temp on a 6 speed? i dont see this as a problem, but i dont know what you do with the truck. i would go ahead and change the fluid if your digging in there anyways. redline MTL.
take out the 3/4" pipe plug on the intake manifold and use adapters to get it down to the size you need. just behind the fuel filter i believe, but you should double check that. pipe plug, it should be between the numbers 4 and 8.
not sure on the gauge pod. try summit racing or jegs or something to that affect. dont believe they would be specific to the dodge but they might work out for you.
Pat
Old Jun 4, 2005 | 10:32 AM
tried genos garage and found a dash pod...but cannot find anywhere if a 2 5/8" gauge will fit or if its for the standard 2 1/16" gauges
and the tranny temp is because i drag race alot and tow a heavy trailer about 6-8 times a year. Prolly could get away without it, but I have it..so why not install it. I already have the tap for the sending unit isntalled (just checked)
Old Jun 4, 2005 | 12:35 PM
caleb c.'s Avatar
Get a boost bolt from Geno's.It works great.But you could just get some stuff from a hardware store and make it work too.
Old Jun 4, 2005 | 03:43 PM
lsgibb's Avatar
The autometer boost gauge I got had everything I needed to install it except for an 1/8" NPT tap and a 5/16 drill bit. Originally I was going to just pull the 3/4" plug and then step it down to 1/8" with adapters but thought that was really cheesy with all those adapters so I drilled and tapped the intake horn instead which to me is a much cleaner install. One thing I did do differently is I inserted the clear 1/8" tubing into some black 1/4" tubing for better looks and added protection for the tubing plus it helps keep the clear tubing from binding up and kinking which it liked to do.
Old Jun 6, 2005 | 01:39 PM
i cannot find the boost bolt on genos site? is it a replacement intake manifold bolt with a tap to screw in the fitting?
i may end up just tapping the intake horn and doing a clean install there.
down the road ill be doing an oil pressure gauge and water temp gauge as well. so ill be back with more questions.
Old Jun 6, 2005 | 01:52 PM
lsgibb's Avatar
That boost bolt is on PDR's website here
PDR
scroll about half way down the page. It's kinda spendy for what you get. If I were you I would just tap the air horn. Just make sure you take the air horn off before you tap it so you don't get metal shavings in your intake.
Old Jun 6, 2005 | 09:26 PM
caleb c.'s Avatar
I don't know were you got your gauges but they gave me the boost bolt for free just by asking.If you got em' from them call and see if they will help you out.Even if you got them somewhere else I would spring for it,it makes a nice install.
Old Jun 6, 2005 | 11:25 PM
upersleder's Avatar
get your pod from scotty, i bought one and its an easy install, and it looks great and is out of the line of sight, but right in front of you at the same time.
http://scottyairsystems.com/
Old Jun 6, 2005 | 11:26 PM
i got them used over on TDR they are in perfect shape...i just need that fitting or boost bolt to do the install next week when i get the truck back from the dealer.
how much is it from PDR...they dont list it on their prices
Old Jun 7, 2005 | 07:38 AM
lsgibb's Avatar
If you go to the pricing page and look under Performance Accessories it is the first one listed PDR 24Valve Boost fitting and it's $18. PDR pricing
Old Jun 7, 2005 | 07:40 AM
upersleder's Avatar
dont need a boost bolt, all you need is a 3/4" to whatever your fitting is bushing, (i needed two to get to 1/8") and install it in the spot on the manifold where the plug is, it was easy.
Old Jun 7, 2005 | 08:17 AM
upersleder, will the scotty dodge pod fit 3-2 5/8" gauges?
do you have pics of yours installed?
i may end up springing for the boost bolt...it just makes for a clean install.
Old Jun 7, 2005 | 08:38 AM
Mcmopar's Avatar
Using the 3/4" to whatever fitting is cleaner looking-it hides way in the back of the engine and is nearly unnoticable. The other options have the tubing out getting in the way of things and look like spaghetti.
Old Jun 7, 2005 | 10:05 AM
lsgibb's Avatar
If I could have found a 3/4 to 1/8" npt adaptor I would have gone that route but hardware stores don't carry that one so I would have had to buy a 3/4 to 1/2 and then a 1/2 to 1/8 I personally didn't like having the extra adaptor and since I already tapped the exhaust manifold and already had the tap and drill bit I figured it was easier and cleaner to just tap the intake horn. I will agree with you that the clear tubing can look like spaghetti which is why I ran it through some black 1/4" tubing first which kept it from getting all tangled up and made it look good.
Hey man any one of these ways will work for ya, it's all a matter of personal opinion. If you feel that the boost bolt is worth $18 plus shipping then you should go that route it would make for a clean install as well.
