Injector trouble
Old Jun 26, 2007 | 08:32 PM
JWC-PERFORMANCE's Avatar
Injector trouble
I am having trouble getting my old injectors out of my 97 12v I cant get them out of the head they are stuck really bad I have sprayed them I have put vice grips on them I have tryed to make a puller but could not find the right nuts and bolts any ideas
John
Old Jun 26, 2007 | 09:15 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
If you are not planning on keeping them, I saw a guy shoot one across the garage by cranking the engine over because it was stuck
I don't recommend this method but it sure as heck worked
Old Jun 26, 2007 | 11:49 PM
DL1221's Avatar
Search the 12-valve forum for Injector Puller. You can make a neat pulling tool from a piece of pipe, like electrical metal conduit, then use a lugnut to force the injector out. Works very easy and is very cheap and easy to make. Look here:
https://www.dieseltruckresource.com/...jectors+lugnut
Old Jun 27, 2007 | 05:11 AM
robert chilton's Avatar
The electrical conduit works well but the EMT connectors work a little better. The metal is slightly thicker so it wont bent as fast. Not to mention they are around a buck apiece.
Old Jun 27, 2007 | 01:24 PM
frostytj's Avatar
You dont even need conduit or pipe. Should be able to double stack the retaining nuts and then use the lugnut.
ridlangus123
Dec 30, 2013 08:36 PM
Doug Crall
15
Jun 20, 2011 12:10 PM
jefro
Jul 17, 2008 07:10 PM
35xj
Dec 2, 2007 08:15 PM
Dave88LX
34
Nov 28, 2006 02:24 PM
