If one had the opportunity
So here's the question,
If you had the opportunity to be the head of a little race team with limited funds, ($15000 annually) . What would ya'll recommend for the first year of spending on an 01 auto 4x4.
It might happen!!??
It might happen!!??
are you supposed to buy the truck out of that 15k? if so, you aint going to get much. Not much at all. but if you already have the truck i would do something like
p-pump
BIG ole twins
huge injectors
and depending on the race or what ever were doing, nos
go through the head, p&p, decked compleatly rebuilt, o rings, studs
cam
pistons
and that will just about take care of your 15k
p-pump
BIG ole twins
huge injectors
cam
pistons
Forget BIG twins. They spool too slow unless you got a really loose converter and want to launch at tranny-breaking boost levels. Besides, EGT control isn't that important for a 1/4 mile. What you want is a largish single a a big hit of nitrous.
Unless you get a mega-built driveline that can handle 20+psi launches (I'm not aware of any that can for long), then turbo spool is a factor and, imo, more important than peak EGT control.
The best money you can spend on making the truck fast is first making it light. Gut about 1500lb and you'll gain a LOT.
That said, here's my prescription:
1) Smarty- ~$650
2) Blue Chip Redline box ~$1100
3) HTT Pro Street 66- $1870
4) Nitrous Express Progressive Nitrous system-- $1200
5) Billet DTT, flexplate, etc-- ~$6000
6) Mach 7s (for the nitrous)- ~$1200
7) F1 Helix 3 cam and springs- ~$1700
With the above system dialed in, you should have a solid 11 second truck that will pull strong to 4K rpm.
Be sure you get the 89% or looser DTT converter. You don't want to bog on the line.
JH
1) Smarty- ~$650
JH
ok heres what i would do fire ring the head, head studs , port and polish the head, 60lb vavle springs , titanium keepers for the valve springs,a VA box stacked with a Redline box , a silver bullet turbo , a H3 cam , with a set of releieved pistons so you dont smake a piston , for injectors i would go with a set of schied 7x18's also a dave goerand full billett trans . the reason i say go with dave is the warrenty on the converter cant beat a lifetime no questions asked . plus if you dont like the way it spools send it back and he will work with you till it spools the charger the way you want it to . also theres stuff like driveline loops , u joint shields and ladder bars. that should get you pretty far .
now if you do go with a p-pump i would look at the schied p-pump install kit its got most of the stuff you need in it . minus a pump wich you can pick up off here or ebay.
just some ideas
just some ideas
just some ideas
just some ideas
I like Hohn's idea's with the "small" charger and nitrous...I've been around a larger charger (71mm class) using A LOT of nitrous to leave the line hard (1.63 60') and the intermediate shaft didn't last long. I kinda attribute it to all that power being released FAST.....but I'm no expert!
Fast spoolup is your friend, for you're tranny's and your EGT's sake!
Chris
I would go this route....
PDW Drugpusher turbo
ATS manifold
AFE filter
NX progressive system
Mach 8's
Tranny
Port, Stud and o-ring the head
TST Competition
Edge EZ
F1 cam and springs
Z rated tires
Roll cage
Good for 850+ RWHP and one fast truck......
Doug Smith
ATS manifold
AFE filter
Mach 8's
Tranny
TST Competition
Edge EZ
F1 cam and springs
Z rated tires
Roll cage
Doug Smith
Hey the tires and cage are so you can live to race again.... Heck with this setup you will need the cage just for the track to allow a second pass!
As for the drugpusher it is designed to be run as a single on nitrous. Fast spoolup and a free flowing exhaust allow for big HP and low backpressure. This turbo will be easy to build boost at the line and really come on hard allowing for the nitrous to be introduced rapidly.
Doug Smith
Doug Smith
