I ordered some Opti-Lube
Old Feb 15, 2010 | 07:15 PM
rattlebox01's Avatar
Hey guys, I ordered some opti-lube summer blend last night(it's not gonna be cold enough to need winter or xpd blend now) and was wondering if anyone else has tried it. I was also wondering why use 2 stroke oil when the opti-lube is quite a bit cheaper per treated gallon/tank of diesel however you look at it and scored better on the lubricity test of Alvin Spicers?
Old Feb 15, 2010 | 09:47 PM
Tate's Avatar
I would say two stroke is more convenient, since you can pick it off the shelf. No need to order it.
Old Feb 15, 2010 | 10:38 PM
Ace's Avatar
Ace
How much did you pay for your Opti-Lube? 2-stroke costs about $3/30gal. tank.
Old Feb 16, 2010 | 08:47 AM
30 gallons of 2 stroke for $3? You must have connections somewhere. It's $11 a gallon at Wal-Mart which is where nearly everybody buys their tcw3. I paid about $20 for a quart of opti-lube to treat 750 gallons(3000:1 ratio) so it's about 2.5 cents a treated gallon where as 2 stroke from walmart at 1 oz/gallon would be about 8.5 cents a treated gallon.
Old Feb 16, 2010 | 10:11 AM
nelrod's Avatar
Hey rattlebox, I would be interested to read that lubricity test. I use biodiesel since I have easy access and it is the same price as other, making it essentially free (for the lubricity). Good luck with the opti lube, let us know how you like it.
Old Feb 16, 2010 | 12:30 PM
Ace's Avatar
Ace
No, I meant $3/30gal. tank of fuel - about a quart of 2-stroke.
Old Feb 16, 2010 | 01:58 PM
AlpineRAM's Avatar
At least for me any more than an 1/800 mix with tcw3 did nothing.
Meaning no improvement over 1/800.
This is for euro diesel, so Ymmv.
Old Feb 16, 2010 | 02:46 PM
Oh, ok. $3 a tank. The opti-lube is still quite a bit cheaper though. The ratio I've been using of stroke (1 oz/gallon) would be $2.55 for a 30 gallon tank and the opti-lube will cost .75 cents for a 30 gallon tank. Here is the link to the lubricity test. http://dl.dropbox.com/u/42304/Diesel...itive_test.pdf It says it costs .68 cents to treat a 26 gallon tank with opti lube summer blend and $1.11 with 2 stroke but they only treat with a 200:1 ratio.
Old Feb 17, 2010 | 03:54 PM
sheriffav8r's Avatar
I've used Opti-Lube summer blend for about 2 years now. I bought a gallon of it and can't remember the price. I use 1/2 - 1 ounce per 20 gallons. Usually about 1 1/2 ounces per full tank. Don't know about the mileage or lubricity improvement but, can't hurt, might help. I've also used 2 stroke and that gets pretty expensive quick.
Old Feb 19, 2010 | 07:57 PM
skidlyman's Avatar
I'm using Opti-Lube XPD it says right on the bottle to use it at 1/4 to 1/2 oz per gallon of Diesel . All i can report, as I just started using it today. ( does seem to make the engine run quieter)
Roperteacher
50
Nov 12, 2007 12:14 PM
wrm
26
Oct 30, 2007 08:09 PM
atwater
Oct 26, 2007 09:54 PM
Roperteacher
27
Oct 25, 2007 06:15 PM
wrm
Oct 17, 2007 04:11 PM
