I Lied
Old Feb 8, 2005 | 11:40 AM
Dieselcamper's Avatar
Talking I Lied
I told myself after the 4" exhaust and Van Aaken box,
"thats it". Now after two weeks with the box I want to
add some "275" injectors,then "thats all". What would
my final numbers be HP/Torque ? Also, if my fuel pressure
never drops below 7-8psi at WOT,do I really need to upgrade
the fuel lines with this setup.
Old Feb 8, 2005 | 11:56 AM
gunracer1's Avatar
340 at the rear wheels, is what i would guess maybe a bit less. but it will be a towing machine.
Old Feb 8, 2005 | 01:08 PM
mikelr's Avatar
I think once you put in those 275's that you may see your fuel pressure at WOT dip a bit lower. You may just want to add a Carter 4600HP 8psi pusher down on the frame rail, it will also help your factory LP live to a ripe old age
You will like those 275's, it will feel like what the VA box did to your stock truck.
Old Feb 8, 2005 | 02:13 PM
Do the Bosch 275 injectors come in a matched set
of six. How do you know if the "pop off" pressures
are all the same. I'm not looking for the absolute cheapest
price ,just want good quality. Can anyone reccommend a vendor
for the Bosch RV 275 injectors.
Old Feb 8, 2005 | 02:36 PM
70crewcab's Avatar
why in GOD's name would anybody buy less than a 100hp injector???
Less than 100hp won't make smoke at will and won't give enough power to justify the sixpack to put them in
Old Feb 8, 2005 | 02:45 PM
CTD_Neil's Avatar
AMEN! I'm tired of my DD3's already.
Old Feb 8, 2005 | 02:54 PM
I'm currently at 51,000 miles and want this truck
to last a long time ,so I am staying on the
conservative side. If I go with bigger injectors
doesn't that lead to pusher pump, new clutch,
EGT issues , etc.
Old Feb 8, 2005 | 03:46 PM
justinp20012500's Avatar
The bosch 275's will give you a smoother idle and better fuel economy. They are brand new injectors that should not require a core.
Justin
Old Feb 8, 2005 | 04:25 PM
GIT-R-DONE's Avatar
HP should put you in the neighborhood of 300. Tq somewhere about 750 +,-.
Old Feb 8, 2005 | 04:34 PM
Cummins4Life's Avatar
This is a very wise man.
Old Feb 8, 2005 | 04:39 PM
Were is the best place to buy them. Local injector
shop quoted $69.95 ea X 6 = $419.70. Online
shops have them anywhere from $285 - $350.
I want genuine Bosch not some knock off.
Old Feb 8, 2005 | 04:40 PM
Call Rip last quote I got from him for 275's was $300 for new set form Bosch.
http://www.sourceautomotive.biz
Old Feb 8, 2005 | 06:42 PM
For those of you out there that have installed
their own injectors. What was the hardest part.
Just looking at my engine injector #6 must be
a bear.
Old Feb 8, 2005 | 06:46 PM
Its cake really. The hardest part is usually loosening the #6 injector line at the head and getting all the little injection line retainers back where they're supposed to be. If you can change your oil you can swap injectors.
Old Feb 8, 2005 | 06:55 PM
mishkaya's Avatar
Changing injectors ended up being considerably easier than I had been led to believe. It only took me about two hours, and that was taking my sweet time making sure to do everything just so. Not all that difficult really. If you would like to read the instructions you can download them here:
http://www.lib.uaa.alaska.edu/~tibor...structions.pdf
My advice would be to do the work yourself and save the cash.
Mishkaya
