hy/35 blues
hy/35 blues
well with everything going on currently. my turbo is starting to leak. i just got some new injectors and was wondering if a hx/35 would work or what i should upgrade to. i just got some used injectors.about 75hp added and figured i need more air. ill be running my edge easy and injectors only for now with my 4" exaust.
I remember living with my HY-35 when I had EZ and DD2 injectors (80 hp, I think). No egt or smoke problems but the turbo would over spool at WOT.... if I remember correctly, could hit 40 psi.
An HX-35 would be relatively cheap and should not exceed the 35-38 psi recommended as max for that turbo.
If no plans for more power... should be just right!
There is a 35 Hybrid and a regular HX-35 that sound like good buys ..... in the Classified Section!
RJ
RJ
thanks
ok so looking in the classifieds. my choices are :
hx-35
modified hx-35 (2 diffrent ads)
dodgezilla hx-35/40 hybrid
are there any diffrences from the 12v to 24v turbos. and would they mount up the my 4" downpipe , or would i need to change thet too!
thanks
hx-35
thanks
If your 4" exhaust fits your HY-35, it will fit stock HX-35 turbines also, unless modified: you need to ask sellers.
Max Air (lowest EGT's) would be from the 35/40 hybrid. Dodgezillas are supporting several 400 hp trucks I know. All things equal, this would be my choice. More room to grow.
On the other 35's you need to find out the trubine housing size. You will want a 12 cm2 housing for your automatic, unless adding more in near future. A lot of HX-35's have 14 cm2 housings and will have more lag on lower hp trucks.
RJ
RJ
