HX-35 and 5-spd Quarter Mile Times
What are you guys running with HX-35's, and 5-spds? Has anyone made a pass in the 13's? What turbo would you recomend to get a 5-spd into the 13's? I havnt been to the track yet with my new setup, but I am running a HX-35, Edge EZ, Powershot Propane, and Blue Chip Premium FMS. I would like to add some injectors but am not sure what to do with the turbo to keeps EGT's in check and still have fast spool up. Would going to a 14 or 16cm work? Also, what is a 8.90 1/8th mile equal to for a diesel in the 1/4. What is a 9.40 equal to? I am used to running my drag car and things are much different.
Re:HX-35 and 5-spd Quarter Mile Times
Also post your trucks weight, and if it is a 4x4. Mine is a 2wd dually, 4.10's, Posi, and weighs around 6100 with a 1/4 tank of fuel.
All my info is in my sig. Truck weighed around 7000 at the time I ran the 1/4. If your truck is that light 400 HP should get you into the very low 14's to real high 13's. If you go injectors, and keep the drugs you should look at Kurt Yardleys turbos.<br>
Forgot to add this this.<br><br>60' 2.239<br>1/8 9.634 @75.77<br>1000' 12.399<br>1/4 14.72 @96.95<br><br>I was out of RPM's before the traps. Since I have gone up two tire sizes and shed a few hundred pounds.
cumminsdriver635
Competition / Pulls / OffRoad
15
12-27-2007 07:34 PM
Captain Insane-O
15
10-05-2003 09:30 PM
