HTT 62/14 with HT3B twins???
Old Jan 19, 2007 | 08:00 PM
98.5POS's Avatar
I've been told that the HT3B is too small to run with my HTT 62/14. I've read on here that it's a popular combo. Some one suggested a S400, would that be better for what I want?
My goals:
-500HP (so not to nuke my NV4500 12.5 clutch)
-Drive daily and some longer trips
-Have enough power to beatup a Powerjoke or Duramax.
-be reliable
Am I asking for to much here? What do you guys think?
Thanks again
DH
Old Jan 19, 2007 | 08:04 PM
thekidfan's Avatar
It will work very well!! 500 should be fairly easy with that combo and also run fairly clean, I'd suggest a smaller ex. housing for the 3b to aid in spool-up! At 500 horse this combo will not be working hard at all
Old Jan 19, 2007 | 08:21 PM
98.5POS's Avatar
The 3B I have right now has a 20cm exhuast housing (split design) - I planned on switching it to a 27 (split design). Maybe I won't. Are you running twins?
Old Jan 19, 2007 | 09:50 PM
thekidfan's Avatar
A 20?? wow hadn't heard of anyone with one of those, I run a 3.5b with a 22 un-divided housing under a 62/.8 Brad Ponci has put quite a bit of time into porting and quick-spooling both my housings and he also added a gate to control the bottom charger very sweet setup!!
With that small housing you will want to watch that 3b depending on the fueling you could over-speed it without a gate on it, but spool-up should be very very fast! I have a couple 26 housings and a 23 if you decide you want a bigger one let me know. Jeff
Old Jan 20, 2007 | 04:37 AM
95ram's Avatar
IMO get rid of the 20 and go with a 26. That 20 will kill you on top end flow. Just my two pennies.
Old Jan 20, 2007 | 08:24 AM
98.5POS's Avatar
Will a 26 spool my 62/14?
Old Jan 20, 2007 | 09:23 AM
dieselfan's Avatar
the 62/14 spools the ht3b.
Old Jan 20, 2007 | 04:15 PM
BCSCUMMINS's Avatar
Your HTT 62/14 should support your goals they are suppose to support 450-525hp.
Old Jan 20, 2007 | 08:28 PM
98.5POS's Avatar
I think I'm going to look for a S400 instead of my HT3B. edit
Old Jan 20, 2007 | 09:11 PM
paulb's Avatar
I think that is a good move. The piping will be easier with the S400, if for no other reason.
Paul
Old Jan 20, 2007 | 09:29 PM
BigBlue's Avatar
After playing with my PS62/12 I can't imagine what it would be like with an S400 underneath it.
Old Jan 20, 2007 | 09:32 PM
blackdiesel's Avatar
Registered
yeah me either! but im gunna find out
Old Jan 20, 2007 | 11:03 PM
12valve's Avatar
look at citydiesel.com for the s400
Old Jan 21, 2007 | 07:54 AM
dieselfan's Avatar
its www.citydiesel.net .
Old Jan 21, 2007 | 08:14 AM
98.5POS's Avatar
Thanks. I wondered where it was.
