HT3B or BHT3B?
Old Apr 26, 2006 | 03:38 PM
12valve's Avatar
HT3B or BHT3B?
i found out the price of these new schwitzer turbos,
the BTH3B is 1,200 pesos (120 USD) more expensive then the Ht3b.
The seller said the BHT3B spools a lot faster then the ht3b
i think the ht3b has a dived inlet.
can i save that money for a twins setup?
thx
EDIT: or i can have an used one for 300 bucks... but its a BHT3E
Old Apr 26, 2006 | 04:12 PM
rharveysr's Avatar
BHT3B....
Rick
Old Apr 26, 2006 | 06:15 PM
12valve's Avatar
Originally Posted by rharveysr
BHT3B....
Rick
what is the difference? and why do lot of them twins guys just talk about HT3B?
Old Apr 26, 2006 | 10:23 PM
DTroy's Avatar
The BHT is machined for a map width enhancement.
If it were my truck, I would run it.
Old Apr 27, 2006 | 04:28 AM
95ram's Avatar
The bht3b will spool quicker, but the ht3b will out flow it on the top end.
Old Apr 27, 2006 | 07:52 AM
gunracer1's Avatar
i have had a few different bht3b's and ht3b's. and the funny thing is they all had different size inducers. the one i run on my truck right now has a 2.9" intake, i have one in the shed with a 2.8. and i have another that is just shy of 3"s. i would ask to see exactly how big it is.
Old Apr 27, 2006 | 10:07 PM
12valve's Avatar
do you think i will regret going with the Ht3b?
interesting to hear you had both tested. is the power difference very noticable... meaning both: faster spool up w the "BH" and more top with the "H"
SO... what inducer size is best??
and: they are remanufactured. is that a problem? sum1 said yes.
thx fellas
Old Apr 28, 2006 | 08:33 AM
gunracer1's Avatar
it really is not going to make as big a differance as you think. any turbo with a inducer size of 2.7 to 3.0 will work just fine. towing works best with a smaller exhaust housing and horse power is made with a bigger exhaust housing. i would suggest you pick up a turbo with a map cut in it, just because it will be of a newer design. what are you hp goals?
Old Apr 28, 2006 | 09:13 AM
12valve's Avatar
what is "a map cut in it?"
my goal: about 500 HP
or 109 mph in 1/4
Old Apr 29, 2006 | 02:11 AM
swank's Avatar
the 3E wouldn't be a terrible idea. that's what i'm running and am quite happy with it. with that and a hybrid on top i was running out of fuel somewhere over 400hp. haven't dyno'd since adding a bunch of fuel, but i'm pretty sure it'll keep up.
Old Apr 30, 2006 | 01:08 PM
12valve's Avatar
i looked at the used 3E again...and it was bad. so i wont go with that one.
OK. how many have only the HT3B /26 ? and how is it?
I think about buying that one? or should i pay the extra 120 bucks for the BHT3B?
wldman32
Feb 17, 2006 10:48 PM
2500TurboDodge
Jan 21, 2006 07:09 PM
Hot Rod Deuce
Apr 21, 2005 08:26 AM
1ST GEN.
Jan 13, 2005 03:22 PM
