HT Turbos for Compounds??
Old Sep 17, 2007 | 02:39 PM
BigBully's Avatar
I have a HTB2 that I am running now and I want to use it as a Top Turbo and then an BHT3B/26 for the bottom turbo. Do you guys think that will work good?
Old Sep 17, 2007 | 02:54 PM
mcoleman's Avatar
It would work fine, but I think an S400 would make a better bottom charger .
Old Sep 17, 2007 | 04:26 PM
Turbinator's Avatar
Why is everyone always so quick to recommend the S400 over the BHT3B? What makes it so much better?
Old Sep 17, 2007 | 04:42 PM
HOHN's Avatar
Newer technology. Higher pressure ratio capability-- more flow, more efficiency.
jmo
Old Sep 17, 2007 | 04:45 PM
RonA's Avatar
It's a little more compact, and a bit easier to make the plumbing. There are also many variations that will work. Both Borg Warner and Garrett primaries will fit the same piping setup. That is a plus for those of us that have a hard time making up our minds.
Old Sep 17, 2007 | 05:35 PM
signature600's Avatar
was an understatement Ron
I like the S400 style chargers..easier plumbing, and a better charger! It's win-win!
Chris
Old Sep 17, 2007 | 05:41 PM
Rodram2002's Avatar
plus if you run out of air, you can upgrade the S400 to an S480.
Old Sep 17, 2007 | 07:50 PM
RonA's Avatar
You can also go down to a K31 if you have room to move your downpipe rearward. I've even been trying an S400 turbo that has a 75mm comp wheel and spools very close to my k31. lots of cool things to try.
Old Sep 18, 2007 | 09:40 AM
BigBully's Avatar
Sounds like the S400 is the way to go. Its only $25 more so I think I will go that way. Does the bottom charger just hang from the Exhaust of the top charger? or does it need some kind of bracket off of the engine? What about oil feed to the bottom Charger?
Old Sep 18, 2007 | 09:52 AM
paulb's Avatar
Source Automotive has a bracket to support the S400. The bracket also incorporates a drain for the large turbo. Do not just let it hang. There is a plug on top of the oil filter housing for another oil supply.
Paul
Old Sep 18, 2007 | 12:54 PM
13FOX's Avatar
There is also an oil port on the back side of the block you could use for an oil drain as well.
Old Oct 5, 2007 | 06:41 PM
BigBully's Avatar
I think I am getting ready to buy the S400, Does it come in different E housings or just one size?
Old Oct 5, 2007 | 07:46 PM
HOHN's Avatar
Bullseye power shows three housing sizes on their site.
Old Oct 5, 2007 | 10:18 PM
BigBully's Avatar
ok but what if I will be buying from Industrial injection? I dont see any options from them.
Old Oct 6, 2007 | 12:32 AM
HOHN's Avatar
I don't either, but I'd think they can get any B-W housing for that turbo.
A call would let you know for sure.
jh
4969joes
Jan 14, 2012 11:00 AM
dditt0635004x4
13
Feb 7, 2007 12:36 PM
BigBlackBeast05
Jul 24, 2005 09:47 PM
1320
30
May 31, 2003 01:01 AM
