HRVP44 with Smarty?
Old Mar 13, 2006 | 02:31 PM
BobQ's Avatar
HRVP44 with Smarty?
I know that the HRVP44 is supposed to give good bottom end, and I know the Smarty gives great low end, so what would happen if I install a HRVP44? Would I have to turn down the Smarty so as not to break anything?
I have heard the HRVP44 is suposed to be more durable and would like to try one when the time comes, but really, I think I would want more mid and top end fuel.
Any way, does anyone have one who can coment?
Also, I would run only the smarty, no wire tap. Truck is an Auto.
Thanks Bob
Old Mar 13, 2006 | 02:36 PM
RickCJ's Avatar
Thanks Bob
The SHOVP44 seems to give more performance on the upper range, so I think with what I've hearing about the Smarty that they would work very well together!
Old Mar 14, 2006 | 12:00 AM
Ph4tty's Avatar
If you need to replace your vp-44 and want more power, then by all means get the hot rod or super high output model for the extra cost of what a wire tap box would have cost you. If your vp is in good running order look at a set of injectors to go with that smarty. JMO.
singleturnout
Feb 20, 2006 05:53 AM
Gene007
Jan 14, 2006 08:32 PM
Terraizer
Dec 14, 2005 07:28 AM
95ram
Nov 12, 2005 08:45 AM
