How much Torque?
Old Jan 11, 2004 | 01:30 PM
Sonny's Avatar
How much Torque?
Hello, I have a 94 cummins with a #5 fuel plate. Different spring to go 3000 rpm. It was an auto originally but the previous owner converted to a 5-sp. The previous owner said it had around 250 horses. Is that about right? If it has 250 hp then how much torque would it have? Thanks, I am new to the cummins.
Old Jan 11, 2004 | 02:05 PM
Smokee's Avatar
My truck is also a '94. I have 720 pounds of torque.
Old Jan 11, 2004 | 04:05 PM
Steve Roseman's Avatar
Depending where you have the plate, you should be close to 250 with a #5 in a 160 pump. I would bet you're closer to 650 torque with the stock injectors.
Old Jan 11, 2004 | 04:36 PM
Sonny's Avatar
Thanks for the info everyone. Yes, it has the original stock injectors. Also a K-N filter straight pipe and pyro-boost gauges. It only has 104,000 miles, the 5-sp has been gone through and has 20.000 miles since rebuild.
mitm
Aug 16, 2009 09:29 PM
Firstgenfanatic
May 14, 2008 06:17 PM
mainer
Jul 17, 2007 07:13 PM
PapaSmurf
Dec 19, 2003 02:14 PM
Davidp
Feb 1, 2003 05:49 AM
