How much of a "seat of the pants" feel would I get from swapping to a #100?
Old Feb 21, 2009 | 08:15 AM
Common's Avatar
And will my headgasket hold up?
Drivetrain?
I wanted a little bit more power - and was thinking of trying a #100.
Or should I go with my original plan of DDP 75's?
Old Feb 21, 2009 | 08:30 PM
Tate's Avatar
It'll be stronger on the top end, won't lay over like it does with a 10 plate. Depending how deep you cut it and where you position it, it could be a lot more fuel, could be the same in the mid range. I've got my plate about 80% forward, pulls good, hitting around 46 psi right now, but the wastegate opens around there anyway.
Old Feb 22, 2009 | 11:44 AM
rebel5422's Avatar
Drivetrain?
go with a #0 and slide it all forward and get a clutch that will hold so far ive had good luck with my truck i just need a bigger turbo and some sticks
i also forgot idk if anyone else has had this problem but the day i installed my plate was the day i threw out my carrier bearing coincedence maybe but i had to change it out and the only place i could find that had the right one was the lousy dodge house but other than that and my oem replacement clutch slipping when i lay into it my truck has done great for only the stuff in my sig
Old Feb 22, 2009 | 04:50 PM
13FOX's Avatar
Big kick if you add some 5x18's and twins to go along with it. And a CD-pump. Outran a BMW Z4 and backbacked off when I hit 120 cause wifey was not happy with me.
Old Feb 22, 2009 | 06:01 PM
dieselman2300's Avatar
I personally like my #100 plate better than the #0 I had in the truck.
The 0 would put the fire out down low, dumping to much fuel. The 100 has a nice ramp up in fuel.
I am ordering a #6 to give that a try. From what I understand the 6 has better around town daily driving charecteristics, but when you want full fuel it has that also.
wcbcruzer
Mar 25, 2008 10:55 AM
westcoaster
Nov 30, 2007 08:06 PM
KVD
Jul 3, 2007 06:38 PM
KVD
Dec 15, 2006 05:39 PM
belfert
Dec 5, 2003 08:53 PM
