How Much Power!....
How Much Power!....
I have an 01 auto 4wd. I am thinking about doing these mods and wanted to get some ideas of how much power it would put down. Also how would it do as far as towing goes. And would it make a good combo I already have the super b and i want to be able to use it for towing and a play toy.
mods are
Super b /S400 twins, (don't know what size B2 any ideas would be good)
drag comp/smarty,
ddp 200hp injectors,
maxspool 2 or Helix 2 cam(which would be better)
F1 pro/sportmans springs
Studs and o-rings
DTT trans
mods are Super b /S400 twins, (don't know what size B2 any ideas would be good)
drag comp/smarty,
Studs and o-rings
DTT trans
get the adrenaline instead of the smarty/drag combo. Would probably be cheaper anyways if you have to by both of the other boxes.
You would be looking at the 575-625 hp range.
Cant really comment on the towing because i dont know the weight you will be pulling.
Adrenaline is by far the best towing box out there. It has incredible egt control programming that allows you to maintain near peak HP and still control dangerous exhaust temps.
Adrenaline is by far the best peak HP box as well.
mods are
drag comp/smarty,
Studs and o-rings
DTT trans
drag comp/smarty,
Studs and o-rings
DTT trans
A standard b-2 should work fine and the smarty will not make any more power on the dyno stacked with the drag comp but make street driving alot more responsive. 200hp sticks will be about as big as you wanna go and still tow decent. Recomend Helix 2 due to many regrind failures. F-1 springs. 12mm ARP studs. And on the trans DTT makes a good product, but lack severly in the warranty department, Goerend is also a great trans aswell with the best warranty in the business.
Brett
Brett
Brett
Yeah thats the standard B-2, and for a trans you would need all the internal upgrades a normal trans gets along with a billet input and also recomend a billet out put. Are you looking to get a built unit shipped to you to exchange?
Brett
Brett
cody323
Oct 19, 2008 04:24 PM
jjrightmire1973
Aug 12, 2008 04:29 PM
J-man
Dec 22, 2007 10:45 PM
redneck rebel
Mar 17, 2007 12:36 PM
