How much is to much
How much is to much
I have hx35 with other mods, and can alway's pull about 35 pob empty and about 41 pob towing I see alot of your profiles that say 24pob max or boost set at 28 ect. ect. Am I running to much boost?
Re:How much is to much
34-36PSI is the top of the efficiancy range of the '35.
A '40 wil be a bit higher, but with more flow out the exhaust the power will be increased a fair amount from the restrictive '35.
45-50PSI is critical overspeed for the HX-35.
At 34 or 36PSI the air coming out of the turbo is 400*F, not a good temperature to make power.
Merrick
Merrick
i dont have a hx,but i have a hy and everybody tells me its no good after 26lbs of boost(hot boost after 26),but my truck would run 1250 in under an eighth.i plugged the wastegate,now it runs 32 lbs. of boost and all the egt`s i will see is 1050.it would only make 21 lbs. boost with the wastegate.if i were you,i would test it myself,and do accordingly.if you are at around 38-40 lbs with a hx you are doing about all you can hope for with that turbo.
From: Drive till ya hit a Polar Bear, then go back 50 miles
Re: How much is to much
Rod
Originally posted by Racer57
Do you have any forced air inductions in mind Rod?
Nope, don't know of one off-hand
Seriously though, from the EGT results we've seen, any of the forced induction units such as the Scotty II, Volant, and Air Bulldog hoods seems to give you a little more leg room on your turbo.
Naturally, since we build them, we're a little partial to the Scotty
Rod
MR. GADGET
Apr 24, 2003 02:51 PM
GaCamper
Feb 4, 2003 12:30 AM
