How much HP will I gain?
Old Dec 12, 2007 | 02:51 PM
ScreaminEagle's Avatar
I'm planning on a XZT+ and 275 injectors. How much will I gain?
Old Dec 12, 2007 | 03:09 PM
C2O's Avatar
C2O
you'll gain high drive psi. if you're not planning on a turbo.
Old Dec 12, 2007 | 03:51 PM
haloman's Avatar
That wont overpower his stock turbo. Just will need a boost elbow set to 32psi. Its a great towing combo.
Old Dec 12, 2007 | 05:26 PM
jp8819's Avatar
My guess around 40-50 hp is about what i noticed and noticed it alot more when towing. Its also enough to need a clutch if you hot rod it much, Dont ask how i know. lol
Old Dec 12, 2007 | 06:11 PM
So then can I figure 70hp/200lbs of torque with the XZT+, and another
40-50hp/100-120lbs of torque with the 275's? Total of around 120hp/300lbs of torque?
Also, why does the boost need to be held at 32psi?
Old Dec 12, 2007 | 06:14 PM
haloman's Avatar
That would be close an estimate for the engine HP RWHP will be about 300hp. Anymore than 32psi will be out of the map of the stock turbo.
Old Dec 12, 2007 | 06:29 PM
C2O's Avatar
C2O
oh ok i was thinking 275hp injectors as if he were getting custom ones. sorry you should be fine with that setup then. its a pretty standard combo.
Old Dec 12, 2007 | 08:03 PM
What do you mean "out of the map of a stock turbo"?
Old Dec 12, 2007 | 08:09 PM
Ph4tty's Avatar
The stock turbo becomes inefficient at boost levels over 34 thus temps go up =(
Old Dec 12, 2007 | 09:06 PM
Krob's Avatar
I am really confused are you talking about RV 275. If so why would he need to impove turbo or j hook it with a XZT+?
Old Dec 12, 2007 | 09:16 PM
C2O's Avatar
C2O
yeah he is talkin RV275's i think, not actually 275hp injectors
Old Dec 12, 2007 | 09:29 PM
mx684's Avatar
this is just my opinion, but if your going to the trouble to change the injectors i would put in something a little bigger.....like my jammer 3 nozzels, 100hp....they give you quite a bit more power, and even when my truck was chiped and towing 12,000k uphill heat wasnt an issue, it would get to about 1250, but it wouldnt go over that, and it had a good amount of power...
Old Dec 12, 2007 | 09:52 PM
J Lent's Avatar
About 100hp over stock & this would be a awesome towing combo. My brother runs RV275 injectors with a Smarty & it is a great towing combo. The XZT+ will be better yet because you will have the switch on the fly. You could go with 100hp sticks....that would give you even more on the bottom. Heat won't be a factor. I ran 100hp sticks with a Edge comp & superchips stack towing before & it was a nice setup, would get hot with the comp up.
Old Dec 12, 2007 | 09:54 PM
J Lent's Avatar
About 100hp over stock & this would be a awesome towing combo. My brother runs RV275 injectors with a Smarty & it is a great towing combo. The XZT+ will be better yet because you will have the switch on the fly. You could go with 100hp sticks....that would give you even more on the bottom. Heat won't be a factor. I ran 100hp sticks with a Edge comp & superchips stack towing before & it was a nice setup, would get hot with the comp up with a stock charger.
Old Dec 12, 2007 | 10:41 PM
kwast's Avatar
Hmmmmm........... that just happens to be my planned combo. I don't have gauges yet so I was wondering if my egts would be safe?
