how much HP will glacier system support
Old Jun 19, 2007 | 03:00 PM
Nor_Cal_Angler's Avatar
just trying to get a feel for they system as a whole....i may be going that route...i know FASS 95 is good for 500 and the 150 can do more...so what is the glacier system good for.....
will it support 500 as well?????
NCA
Old Jun 19, 2007 | 07:04 PM
Rpainter's Avatar
It depends on what cp3 your are planning on running a stage 2 cp3 likes a constant 25 psi while dual cp3 like a constant 15 psi I think the glacier will do fine I have heard there is afew truck in the 800 plus hp range. I am 650 plus and have had no problems yet
Old Jun 19, 2007 | 08:31 PM
dieselrob's Avatar
A glaicer pump will put more fuel to your vp than it would know what to do with. You actually have to use a return regulator with the glaicer pump because it moves so much fuel. I have one and couldnt be anymore pleased and im over 500, and best part is its the quietest pump ive had yet.
Old Jun 19, 2007 | 11:50 PM
Ph4tty's Avatar
An oem carter pump with a big line kit and/ or a pusher pump will support 500 no problem.
Old Jun 20, 2007 | 09:55 AM
Buckshotmckee's Avatar
He's got a 2nd gen, no CP3. He has the Vp44.
OT-OF-Here
Sep 27, 2006 10:21 AM
6spd24v
Jul 13, 2006 02:04 AM
Igor
Jun 2, 2006 07:49 PM
streetsmoker
24
May 7, 2006 12:26 AM
