How much HP/TQ should my truck be at now ????
Old Feb 19, 2009 | 08:51 AM
Katmandu's Avatar
Question How much HP/TQ should my truck be at now ????
I need a clutch upgrade and trying to decided what level to go with.
See Sig for mods.
These Dyno results were before a couple recent mods...
Dynoed March 08--> 384 HP/853lbs TQ
Recent mods... Waste gate Blocked off. AFC adjusted Full Forward.Truck was pulling 32psi BEFORE the mods. Now pulls around 45psi.
Truck is pulling MUCH harder now!
Where "should" the #s be now ?? "Ballpark".
Old Feb 19, 2009 | 09:21 AM
j-fox's Avatar
What is the EGT?
I do not agree with the idea of blocking the wastegate. It reduces the drive pressure and that protects the head gasket. It also prevents overspeeding the tubo. Do you realize you are pumping a lot of hot air into the motor at 45 psi with a stock turbo?
Old Feb 19, 2009 | 09:50 AM
neveragain's Avatar
How much HP and TQ?
WoW that is alot of both! Just jelious. It would be better to put a gauge in there to check what the air temp? You don't want your intake air to be above the 150*F. Mine would never go above 19 psi boost even blocked off.
Old Feb 19, 2009 | 06:50 PM
kas83's Avatar
You might have cracked 400/900, but not much more. 32-35 psi of boost is about the max for making power. After that, you're just blowing hot air. It's fueling harder purely because of the extra boost, and will pull harder, but isn't making a whole lot more peak power.
Get a bigger lung on that thing and then feel the power difference.
Old Feb 19, 2009 | 09:21 PM
Dglass89's Avatar
i used to be able to get my hx35 to 60 plus but i knew i wast makein any power and then i put my htt on there and wow that turbo at 20 pounds was way more than the hx35 and say 40 pounds you need a aftermarket turbo then you will feel the diffrence and make alot more power
Old Feb 19, 2009 | 09:46 PM
strokin359's Avatar
turbo would help but i have a p pumped 24v with a 215 pump on it with 4k gov springs ddp 240 sticks and a ssp 66 over a ht 60 and its gets plum nasty i drive it every day
Old Feb 20, 2009 | 05:28 AM
12 flapper's Avatar
I am curious but what are your egts.
Old Feb 22, 2009 | 08:41 PM
Katmandu's Avatar
Arrow
Originally Posted by j-fox
What is the EGT?
NO problem at all with high EGTs.
It does momentarily spike up when boost goes past 40psi or so. But that can be expected.
Other than that, EGTs have been a NON-issue.
Only thing now is my clutch can't handle the extra torque.
Old Feb 25, 2009 | 01:36 PM
Katmandu's Avatar
Question
Roger that.
I NEED to get a beefier clutch/flywheel to handle the extra muscle!
What is the next step up (TURBO-wise) over stock ??
Old Feb 25, 2009 | 03:56 PM
Lil Dog's Avatar
At 45 psi you have NO EGT issues? Uh something doesn't add up , I have EGT issues even with a bigger blower and did with the stocker...
Old Feb 25, 2009 | 04:46 PM
Katmandu's Avatar
Arrow
Like I said earlier, it DOES SPIKE UP when the boost goes 40+psi. Maybe, hitting 1000F +/- for a few seconds or so.
BUT, I do NOT run the boost the high for more than a few seconds at a time.
The EGTs usually stay in the 600F range while cruising down the highway. When I go to pass someone OR just feel like going WOT, it EGTs WILL shoot up accordingly. Again, the EGTs do NOT stay high by any means.
I do have 4" straight pipe which certainly helps defuse exhaust temperatures.
Old Feb 25, 2009 | 05:43 PM
dahla's Avatar
Just curious where is your EGT probe located at is it in the exhaust manifold before the turbo or is it after the turbo big difference with EGT's to get an accurate reading it shoud be placed before the turbo
Old Feb 25, 2009 | 06:07 PM
Katmandu's Avatar
Thumbs up
It's in the exhaust manifold BEFORE the turbo.
Old Feb 25, 2009 | 06:31 PM
dahla's Avatar
k just wanted to be sure
Old Feb 25, 2009 | 10:22 PM
BigErksG2's Avatar
forget a new turbo just add one more! hx35 with a s400 or 3b can be great when properly tuned.
