how much does a 5.9 cummins weigh?
Old 05-21-2009, 11:11 PM
kyle_truck_pull's Avatar
Question how much does a 5.9 cummins weigh?
does anyone know how much a 5.9 cummins weighs? I was wanting to buy some engine stands, but I didnt know what one actually weighed fully dressed with fuel system and everything ready to roll. thanks
Old 05-21-2009, 11:23 PM
STate's Avatar
12 valve - 960lbs
24 valve Common Rail - 1170lbs
24 valve VP44 - ???
Im pretty sure Ive read this question posted before. Do a search for it.
Hope this helps.
Scott
Old 05-22-2009, 01:33 AM
Tate's Avatar
Figure about 1200 lbs. If you mount it from the back side of the engine, its gonna sag, no matter what. Mount it from the side, and will stand up much better.
Originally Posted by STate
12 valve - 960lbs
24 valve VP44 - ???
Hope this helps.
Scott
I'd be curious from where the extra 200 lbs. came from between a 12v and 24v. I know the 24v and 12v head don't weight much different, and the 50 lbs. p-pump would add some fat to the 12v number.
Old 05-22-2009, 10:18 AM
randallp84's Avatar
I would be interested to know what tthe 5.9 weighs compared to a 7.3 PowerStroke. Anybody know?
Old 05-22-2009, 10:57 AM
kiohio1985's Avatar
From Ford Manual
7.3 DI TURBO 920 lbs (417 kg)
7.3L IDI TURBO 900 lbs (408 kg)
7.3L NA 860 lbs (390 kg)
Old 05-22-2009, 02:09 PM
randallp84's Avatar
Thanks kiohio. Sorry kyle, didn't mean to hijack your thread.
Old 05-23-2009, 06:20 AM
powermad's Avatar
powerstrokes are aluminum heads right? i also heard that the 12v cranks wiegh over 125lbs. now theres some rotating mass.
Old 05-23-2009, 09:15 AM
J OOPS's Avatar
24v with vp44 weighs 1600lbs fully loaded.
as for the other engines check again, those are weight on the engines not fully loaded.
Weighed the engine at a certified scale at a wrecking yard. The engine had just came out of the truck.
Old 05-23-2009, 10:16 AM
HidalgoGT's Avatar
7.3 is cast iron as well as the 6.0 I am pretty certain is cast iron as well. I know they are.
Old 05-25-2009, 12:04 AM
Tate's Avatar
Is there a tranny and t-case attached to that engine as well? No way engine alone weighs 1600 lbs.
Old 05-25-2009, 01:33 AM
1-5-3-6-2-4's Avatar
agreed no way a B cummins weighed 1600 lbs engine alone. am M11 would weight 1600lbs.
Old 05-25-2009, 01:46 AM
while we're at it. heres 12v 6BTA and 6CTA --- for the record a '91-'94 6C dressed & wet weighs less than 1500lbs.
Old 05-25-2009, 02:38 PM
powermad's Avatar
oh ok so is it the duramax with aluminum heads? and can anyone confirm the weight of the 12v crankshaft? i am still wondering if its really that heavy?
Old 05-25-2009, 05:13 PM
Tate's Avatar
I don't have a scale, but I can tell you the crank is well over 100 lbs.
Old 05-25-2009, 06:14 PM
powermad's Avatar
wow thats a heavy crank has anyone put a 24valve crank in a 12v?? i might be on to something or not. anyone???
Quick Reply: how much does a 5.9 cummins weigh?
