How about this turbo?
Old Jan 3, 2008 | 06:41 PM
Big Blue24's Avatar
First, is this a good deal?
Second, will an HX-40 make more power than this turbo. It claims to be identical to a Super B, and a Super B claims to flow 61 lbs per minute = 800-825 cfm.
http://cgi.ebay.com/ebaymotors/Dodge...spagenameZWDVW
On a side note, a super B special is supposed to flow 80 lb per minute = 1000+ cfm. But if you run the numbers and they claim 550-625 HP to the ground, then by simple math, at the high end 625Hp/80 lb of air = 7.81 hp/lb of air so in theory, that little super B at peak could make 7.81x61 lbs air = 476.6 HP.
Now maybe the super B chokes up and that limits HP to 425, not sure.
Third, I hate turbo lag. In the winter the stock turbo is fine, but in the summer at these high altitudes, it is too slow. I want to be able to roast the tires when the turbo spools in third. Not chirp, not spin, ROAST!
Old Jan 4, 2008 | 06:24 PM
Big Blue24's Avatar
Hohn, where are you? I'm sure you have researched these blowers more than me.
Old Jan 4, 2008 | 07:32 PM
Redliner's Avatar
Thats the one I got on my truck. I got it a WHOLE LOT cheeper than that from the same person. Only problem I had was wastegate wouldnt fit any way I tried. So it not there now....
Old Jan 4, 2008 | 08:21 PM
wurkenman's Avatar
I have the same turbo, and my EGT's went way down. The spoolup is still scary fast. Spools kind of like the HY35 I had from stock, but way down on temps, I like mine
Old Jan 4, 2008 | 11:13 PM
bigd450's Avatar
Are these turbo’s really identical to BD's super b or are there some differences.
Old Jan 5, 2008 | 01:44 AM
kas83's Avatar
BD claims to make some mods to the turbine and the wastegate, but it's really hard to say without tearing both apart.
Old Jan 6, 2008 | 05:17 PM
Redliner's Avatar
Oh and they are gated at 32psi but can be adjusted to 40psi is what they told me. I still couldnt find a way to get it on with the WG.
Ada381
Feb 10, 2008 07:58 AM
j
Jan 9, 2004 08:19 AM
Haulin_in_Dixie
Jul 21, 2003 11:14 AM
redram
Dec 10, 2002 09:54 AM
