Hot pipe ?
Old Dec 6, 2008 | 06:00 AM
gwhammy's Avatar
Hot pipe ?
I've got a hot pipe for a hx35 to a 3b that goes on with the flange clamp. I'm building a copy of it to use a hv351. With this pipe able to swivel do you think it would work for a s400 also? I have to build the cold pipe to clear an on board aircompressor so the cold pipe is a non issue. Any ideas?
Old Dec 6, 2008 | 06:31 AM
RonA's Avatar
Are you asking if it will be able to fit a 3b or s400? The 3b I had had a slightly different bolt pattern than an S400. Also alot different angle where the hotpipe connects to the exhaust housing because of the opposite rotatation.
Old Dec 6, 2008 | 07:48 AM
gwhammy's Avatar
I'll check the bolt pattern,I was just thinking with it swiveling it could be spun around to reclock for the reverse scroll. I have flanges from mpi I'm working with and a hot pipe I bought from quad that fits a 3b. With all the extra time I don't have right now it's all mind game anyhow.Thanks Ron.
whosdunit
Feb 16, 2019 04:07 PM
Strjock81
16
Dec 12, 2007 09:53 AM
edwinsmith
Apr 14, 2006 03:53 PM
duallydave
Aug 7, 2005 09:38 PM
PADZZ
Feb 9, 2003 08:33 AM
