Holly Blue pump
Old Dec 21, 2008 | 04:11 PM
Garrett5462's Avatar
Holly Blue pump
just bought myself one of the Bully Dog big fuel kits. i was wondering if its best to use this pump alone or combined with the stock LP, and if thats the case, before or after it inline. And also, if only running this pump could i just use the power going to to the stocker and splice into them?
Old Dec 21, 2008 | 05:35 PM
sodbuster03's Avatar
Mine has been on for two years with no problems. I'm running both the holley & the stock lp. Far as wiring. The best way in my opinon is to tap into the hot wire going to the stock lp & using it for the trigger wire on a relay. That way you have constant 12v to the holley. If you try & use the stock hot wire as direct power to the holley it could be harmfull to your ECM, from what I understand.
Old Dec 21, 2008 | 05:43 PM
CapnRam's Avatar
Same here, i have had my blue pump on for over 2 yrs, only problem is when it hits -25 or lower, then the pump doesnt want to work, i also used the stock LP wire to trigger a relay, i have the Vulcan big line kit, with just the blue pump, idle at 13 WOT is 9. There is a spring you can "stretch" very little to bump up the psi a bit.
Capn
Old Dec 21, 2008 | 06:39 PM
STACKED's Avatar
i have mine in line no problems for 3 years.
Old Dec 22, 2008 | 06:55 AM
thanks a lot. does anyone know just how much stretching will raise your psi?? ive heard that its better to just use some type of shim, such as a washer.
Old Dec 22, 2008 | 07:49 AM
high bid's Avatar
yea, don't strech it much at all as you'll end up w/25psi like me. You'd probably be good just to leave it alone as I replaced mine and still have 20psi. No hard starts either as some mention because it's not constant 20psi upon cranking. No problems to date.
Old Dec 22, 2008 | 11:22 PM
psd tuner's Avatar
i use my lp wire to power my blue with no problems and i had this set up for over a year with 21,000 miles on it and its still tickin just fine
Old Dec 22, 2008 | 11:28 PM
bamadzl's Avatar
I agree, you can just use the lp wire. Mine worked fine, but the Blue eventually died, hence the Walbro.
Brad
Old Dec 22, 2008 | 11:34 PM
Flatbed24v's Avatar
I used the stockers wires to activate my ppe but I bypassed the stock lp. It is a brand new lp so if the ppe ever fails I can rig up the stocker and know it's still good to get me home just food for thought.
Old Dec 23, 2008 | 10:50 AM
so the holly will push right through the stocker (which is not hooked up) and not lose any pressure or flow? or if im using just one pump should i take the stocker right out. Im just looking for the best way to set this up so i get the most life and performance out of it.
Old Dec 23, 2008 | 03:48 PM
dieselfan's Avatar
sometimes it will flow though, just depends on how it quits working.
he said he bypassed it.
Old Dec 23, 2008 | 06:37 PM
Flatbed24v's Avatar
no fuel flowing threw my stocker, it just sitting there bolted on but no juice or fuel going to it. I use it like a backup pump. I would need to run power and fuel lines back to it in order for me to use it
Old Dec 23, 2008 | 08:04 PM
GUMP's Avatar
Anyone using the black holley pump?
griffy
Feb 13, 2008 08:03 AM
xloudnproud
Apr 11, 2006 06:48 PM
SuperDave4x4
Jul 18, 2005 08:23 PM
OldSmokey
Jan 28, 2005 07:16 PM
Tengu
33
Apr 27, 2004 09:03 AM
