holley blue pump
Old Oct 12, 2008 | 10:45 PM
lefty10's Avatar
holley blue pump
My fuel pressure drops to nearly nothin at WOT and I was wonderin where the best and cheapest place to get a holley blue or a procomp is? thnx
Old Oct 12, 2008 | 10:53 PM
bridleman's Avatar
Just a piece of friendly advice coming from personal experience, don't waste your time with the holley, spend the extra money the first time and get a Air Dog 150 pump and be done once and for all, Great customer service and all the fuel you need to grow. I've been down the same road your heading. JMO Chris
Old Oct 12, 2008 | 11:00 PM
lefty10's Avatar
I would like to go with that upgrade but I just cant spend that kinda money on it I might upgarade to that down the road but rite now I need a cheap fix
Old Oct 13, 2008 | 07:51 AM
high bid's Avatar
FPs are a matter of opinion. Tons of people run the holley blue w/zero issues. When set up correct, they will provide years..............of service. I have not used the procomps yet (installing them on a diesel boat) but it's stated they are the same as holley. You can find new ones on ebay pretty cheap OR try summit automotive.
Old Oct 13, 2008 | 11:43 AM
2whistlers's Avatar
I know far more people that have had bad tastes left in their mouths than not with the Holley pumps.
Old Oct 13, 2008 | 12:34 PM
Adam3291's Avatar
First he needs to determine if he has an intank job or he is still running the stock Carter on the engine. I'm going to take a guess and say intank. If that is the case I would run a Holley Red instead of a Holley Blue. This will allow you to stay right at 15 psi total running the Red as a pusher pump with the intank.
Old Oct 13, 2008 | 12:54 PM
CapnRam's Avatar
I've been running the holley blue pump for over 2 yrs, stock fuel filter, and a vulcan big line kit, I run 12psi idle, and 9 at WOT with the smarty on 8 and the adrenaline on 10! No problems with the holley at all! I have the same one on my 600hp bbc! just my .02!!
Capn
Old Oct 13, 2008 | 05:49 PM
wurkenman's Avatar
I have the Holley blue also and the big line kit. I stretched the spring a little and run 19-21 psi at idle and 15 at WOT.
Old Oct 13, 2008 | 07:18 PM
LittleRedWagon's Avatar
I run a holley black...got it from lane automotive....it wasnt to bad...try getting on their website and looking at them... no problems at all with this pump..cant complain
Old Oct 13, 2008 | 08:31 PM
wurkenman's Avatar
This will be my next pump.
http://www.glacierdieselpower.com/de...dept_id=07-001
Old Oct 13, 2008 | 08:32 PM
lefty10's Avatar
I have the block mounted pump cuz I just had to replace it
Old Oct 13, 2008 | 08:54 PM
psd tuner's Avatar
very pleased with my blue, heck i got it @ o'reilys for 120. the big line kit from vulcan is nice too.
Old Oct 13, 2008 | 09:06 PM
rich's Avatar
had the blue on my 98.5 and my 03 never had a problem with it at all. and for the 185.00 it was well worth it
Old Oct 13, 2008 | 09:21 PM
JakeHunter's Avatar
you can get just the holley blue from almost any parts store, about $150, i have the holley 150 that makes 16 psi and used the stock fuel lines with the stock fuel filter and it works just fine for me.
Old Oct 13, 2008 | 09:57 PM
Flatbed24v's Avatar
I have the ppe lift pump and I love it. It's priced right too $230 for a 160gph pump.
