holley blue install problem
Old Aug 6, 2005 | 01:43 PM
duallydave's Avatar
Angry holley blue install problem
just finishe installing my hollet blue pump,having a problem with the regulator,it has 3 openings marked in on the bottom and 2 outs on the run.in the manual it says you can use the holes on the run for in and out and the bototm could be a retern,i pluged the botom and used the openings on the run and it wont adjust presure.it stays at 13-14psi then i bump the starter and i get 25psi.did i plumb the reg wrong??? **** junk
Old Aug 6, 2005 | 08:00 PM
BigBlue's Avatar
I don't even run the regulator. No reason to. Let the pump run at full flow. Plenty of fuel for our engines.
AlCorr
114
Feb 11, 2009 02:32 AM
Texaschevelle
26
Nov 16, 2007 08:08 PM
duallydave
Aug 6, 2005 02:24 PM
SjLingenfelter
Jul 5, 2004 09:56 AM
ppsi
20
May 15, 2004 10:55 AM
