Holley Blue Install
Old Aug 5, 2007 | 03:44 AM
StevenAg03's Avatar
Holley Blue Install
I just replaced the stock lift pump and im thinking about adding the Holley blue for a little extra help. to plumb it in i was thinking the vulcan big line/relocation kit shown here: Vulcan Pusher Pump System™ for 98.5 to 02
the question i have is this. does the kit have a provision for running both pumps? would i just need extra m12x1.5 barbed adapters? also my current fp gauge is tapped into the inlet side of the filter. i would like to tap in on the IP side of the filter since it is a better reading to find supplied pressure.
my thoughts would be this:
tank to holley blue
holley blue to stock lift pump
stock lift pump to filter
filter to IP
anyone have theirs set up using the 3/8 vulcan big line kit?
Old Aug 5, 2007 | 06:53 AM
Tocapet's Avatar
You're gonna get too much pressure. Shouldn't have more than 14 or 15 pounds to the inlet of the IP. It'll cause hard starts. Just bypass the stock LP & run it straight off the Holley Blue and the bigline. Hook your FP guage to the scrader valve on the inlet of the IP. You could run the stock LP and the bigline kit and do the Holley later. Or you could save the new stock LP as a backup & do the Holley now. Either way, keep an eye on that FP guage.
Old Aug 5, 2007 | 07:01 AM
blackdiesel's Avatar
Registered
NO hard starts here, Have been runniing that way for 2 years now, and I've set up 5 other guys trucks this way with no problems.
Old Aug 5, 2007 | 08:05 AM
2500superram's Avatar
anybody use aluminum hard line and an fitting's,instead of rubber hose.just wondering,because i have alot extra from my car.i figure it would be easy to run it along the frame too.
sorry for the little off topic?
Old Aug 5, 2007 | 06:05 PM
Registered
I just cut the line under the cab, and take out about 6-8" out and put the pump there, using all the hardlines dodge gives you. If your using two pumps the 3/8's lines are fine, if your just going one pump then 1/2" lines are better. JMO
Old Aug 5, 2007 | 08:35 PM
Fishin2Deep4U's Avatar
You'll be fine for hot starting. If you were over 20psi static, I would more concerned.
Eric at Vulcan is a class act!!
Dave
Old Aug 5, 2007 | 11:28 PM
StevenAg03's Avatar
has anyone had any issues using the blue in a diesel application? deterioration of seals, internal components, etc, etc? the website says its meant for gasoline.
Old Aug 5, 2007 | 11:51 PM
txsbigdaddy's Avatar
i put a summit 140 gph 14psi with the stock lp and have had no problems . Live in East Texas, with HOT weather and have had no problems with hard starts. 22 psi @ idle and 15 psi WOT!!! YEA BABY!!!
Old Aug 6, 2007 | 12:22 AM
Some people swear by them, some swear at them.
I would get a pump from someone that deals in diesels.
Dave
AlCorr
114
Feb 11, 2009 02:32 AM
Texaschevelle
26
Nov 16, 2007 08:08 PM
SmokinFive9 4x4
13
Nov 8, 2004 09:46 AM
SjLingenfelter
Jul 5, 2004 09:56 AM
ppsi
20
May 15, 2004 10:55 AM
