Holley Blue
Old Aug 28, 2006 | 01:13 AM
mvanhelden's Avatar
Holley Blue
I was wondering if i were able to just run the holly blue pump on the frame by itself and remove the stock LP. WOuld it have enough pressure for this? I have the bully dog 1/2" fuel lines also.
Old Aug 28, 2006 | 07:11 AM
blackdiesel's Avatar
Registered
Yes, lot of people run it that way
Old Aug 28, 2006 | 08:25 AM
bamadzl's Avatar
That's what I've been doing for about a year. Good results so far.
Brad
Old Aug 28, 2006 | 12:44 PM
Mike D's Avatar
You would be better to run it with the stock lift pump. With the comp on kill it would still pull your fuel pressure down. When I ran the blue as a stand alone, I was still able to pull it down to 7 psi from 15. With the stock pump back in the picture I run about 28 psi at idle and pull it down to about 18-19 psi WOT.
Old Aug 28, 2006 | 01:08 PM
dieseldodge's Avatar
i have been running it that way for a while and i have the 1/2 inch lines also. been working fine. just keep listening to the buzz from the pump.lol
Old Aug 28, 2006 | 06:55 PM
mvanhelden's Avatar
Should I run it from a constant key-on power scource? I tied into the stock LP harness and it doesn't turn on for a few seconds when the key is engaged every time. it does after it sits for awile but it won't do it if the key is switched on a second time without the engine starting. is this normal? or should it come on every time the key is turned on?
Old Aug 28, 2006 | 07:41 PM
i ran mine straight from the battery with a relay set up, and the relay activation is from a key on power source. i used a micro toggle switch from the key on source just so i can turn it off if i have to have the key on and dont need the holley pump running.
AlCorr
114
Feb 11, 2009 02:32 AM
Texaschevelle
26
Nov 16, 2007 08:08 PM
ET_178z
Jun 3, 2003 01:15 AM
cpermd
31
Nov 8, 2002 04:13 PM
