High HP Chips....
Old Sep 22, 2003 | 02:29 PM
SjLingenfelter's Avatar
High HP Chips....
Im wondering why on the HIGH HP chips do they DO NOT USE WHILE TOWING ONLY USE FOR RACING. WHy do they say that?
thanks Sean
Old Sep 22, 2003 | 02:34 PM
moneyman's Avatar
Re:High HP Chips....
If you use it while towing the egt's will get to high and you run the posibility of melting something. You're are putting your motor under a heavier load while towing than you are racing. please correct me if im wrong
Old Sep 22, 2003 | 02:44 PM
AlpineRAM's Avatar
Usually you'll tow longer than you'll race. If you are above the safe limit for combustion chamber temperature it will take time to saturate the material with heat. So, for security reasons you should do the quarter mile as fast as possible
AlpineRAM
Old Sep 22, 2003 | 03:29 PM
JStull's Avatar
Yep, a lot of racers will peg their egt gauges during a quarter mile run or sled pull, but this is only for a few seconds. (the faster the better!). Those boxes are adding more fuel at higher levels which will raise the exhaust gas temps. plus, a motor does more work when towing. It must move a heavier mass than when empty.
-Jason
Old Sep 22, 2003 | 03:34 PM
Thats what i kinda figured but wasnt sure.
Thanks yall
Old Sep 22, 2003 | 05:29 PM
OlBlue's Avatar
[quote author=AlpineRAM link=board=7;threadid=19963;start=0#msg187766 date=1064259895]
AlpineRAM
[/quote]
wick
13
Mar 18, 2003 07:57 AM
zeik
Mar 17, 2003 07:33 PM
Buzz
Feb 4, 2003 08:49 PM
bigbaddiesel
Nov 23, 2002 02:32 PM
ox
Nov 21, 2002 07:47 PM
