Help with power mods
Old Apr 12, 2007 | 11:08 PM
Mav's Avatar
Mav
Hey guys can yall help me think out a little recipe for the So i plan on getting in a few months?
First off ive heard its best to keep the So pump so id probably rather not get a hrvp for that price.
I was thinking maybe mach 6s, tst comp 3, edge ez for timing, bd rad, a built tranny and a ats 5000 turbo with studs. Of course I couldnt afford to do it all at once so what should come first..... any info at all would be appreciated. THANKS
Old Apr 13, 2007 | 12:07 AM
Ph4tty's Avatar
Is this a second truck? I just noticed the '06 in your sig. Sounds like a 600 hp setup for a 2nd gen
Old Apr 13, 2007 | 01:04 AM
Mav's Avatar
Mav
Yea I was thinking for a work/play truck, heck I might even sell the third gen if I like it enough.
Old Apr 13, 2007 | 01:12 AM
Mav's Avatar
Mav
I done gotta question bout the tst. First off I still dont understand why on there website you have an option about what year model to get. Why should it matter as long as whoever buying it understands that on a Ho pump the comp willnot work as well?? is there an actual difference in the software?
Old Apr 13, 2007 | 01:56 AM
Ph4tty's Avatar
Its just that on a ho model the tst comp maxes out all the fuel availble on level 5 which is basically pm3 fueling so you get four useless levels. The comp is a little different- it'll fuel with less boost, make more power (with the right vp44), and it fuel to higher rpms.
Old Apr 13, 2007 | 02:16 AM
Mav's Avatar
Mav
Thanks .................
Old Apr 15, 2007 | 02:30 PM
c-hawk's Avatar
The 02 in my sig had a DTT trans, Edge Drag Comp, Mach 7 injectors, Twins, BD Rad, Head work (including orings by F1 diesel). I would suggest this setup as it worked very well for me.
If your planning on running nitrous, a single would prob be the way to go. But on a 24v i don't think any single will keep up with a good set of twins. Downside is twins cost more.
Chris
tristan21
Jun 19, 2007 04:57 AM
ddestruel
Nov 11, 2003 08:46 PM
Sarge1124
Mar 29, 2003 05:46 PM
rshelton88
Nov 23, 2002 12:34 AM
