help with fass 150
Old Jun 19, 2009 | 06:17 PM
benroberts3605's Avatar
help with fass 150
Got in the truck and when I keyed up the pump did not do its normal half second prime it usually does. bumped the key over and it still wouldnt run the pump manually, so I started it up and it had good pressure 20psi. drove it to a buddys house and when I keyed up it did its short prime. doing this over and over sometimes it worked sometime it didnt. I checked all my wires and they are all good. Also its the first day its in the mid 90"s humid and i filled up today. Is it not supose to do that all the time, could it be heat related. I need help
Old Jun 30, 2009 | 10:26 AM
diggerfan99's Avatar
Fass Fuel
I would guess that your problem isn't with the Fass Fuel because the Fass system only runs when the computer tells it to. I think there is a relay under the hood that is part of that whole system, maybe start there.
rjm022
Oct 20, 2014 02:29 PM
CrashCade
Dec 3, 2008 07:58 AM
dodgediesel
26
Nov 2, 2008 12:20 PM
curts99
Feb 14, 2008 12:09 AM
Ramtuff06
Aug 21, 2007 06:21 AM
