Help!!
Old Aug 18, 2005 | 10:18 PM
isissound's Avatar
Unhappy Help!!
allright so on my new 96 dodge cummins ex cab auto trans 4wd when i am backing in to a parking space when i step on the throughtle and let off real quick my truck stalls also if the truck hasent ben running for about 15 mins or mor and i try and go anywheres when it shifts in two 2nd i practically get lurched threw the window any ideas
Old Aug 18, 2005 | 10:25 PM
J BODY's Avatar
Short 10mm wrench and adjust your idle, it's too low right now. Should be 750 in gear with a/c compressor engaged. Idle is on the bottom of the rear bellcrank. Follow the long rod back from your throttle control up near the injection pump.
Old Aug 18, 2005 | 10:30 PM
isissound's Avatar
allright thanks for that now does anyone have any suggestions on my transmition
Old Aug 18, 2005 | 10:33 PM
storx's Avatar
sounds liek your torque converter is locking up.........maybe cahge the fluid to a syn blend or somesort because some of the triple lock converters will only run off syn brand oil......or thaty run like crapppp
Old Aug 18, 2005 | 10:35 PM
isissound's Avatar
allright any other possibilities
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
