Hearing ENGINE tones through subwoofers
Old Jun 9, 2005 | 12:13 AM
Bobcat698's Avatar
Unhappy Hearing ENGINE tones through subwoofers
After a hard night at a mud bog, bouncing crap around in the cab etc, I noticed that my amp and 2 12" subs "whine" with the RPMs of the motor when I have the volume turned down..
This didn't happen before..
I have the amp hooked to the drivers side battery... Any ideas for me?
Old Jun 9, 2005 | 03:19 AM
95ram's Avatar
From what I remember from my sterio days. It usually has to do with the ground.
Old Jun 9, 2005 | 07:41 AM
Mopar1973man's Avatar
Check you amp & stereo grounds... Also check the truck grounds too...
Old Jun 9, 2005 | 09:45 AM
upersleder's Avatar
HEY you may be on to something, all i hear is how these guys wanna "hear" their engine and boost more.....
Old Jun 9, 2005 | 09:46 AM
HOHN's Avatar
It's a grounding issue for sure. Try to find a body/frame ground near the back of the truck.
Old Jun 9, 2005 | 10:54 AM
Haulin_in_Dixie's Avatar
Or the alternator has a leaky diode. Getting wet can do that. I recently changed my alternator for that exact reason.
Old Jun 9, 2005 | 11:25 AM
Sidewinder's Avatar
Are you running the stereo wires too close to the spark plug wires.
Old Jun 9, 2005 | 01:09 PM
apwatson50's Avatar
I had the same problem for a while, changed the ground, and it went away.
Old Jun 9, 2005 | 03:35 PM
mikmaze's Avatar
nah sidewinder ... back in the day when ford owned cummins they ran the ground wires too close to the sparkplug wires.....
Old Jun 9, 2005 | 10:03 PM
I think the two of you are both a quart low on blinker fluid...
You might order up some muffler bearings too...
Old Jun 10, 2005 | 12:34 AM
killfast1's Avatar
Dont forget the hubcap gaskets. you dont want those leaking.
wannadiesel
Aug 17, 2009 11:10 AM
dlg449
Mar 2, 2007 02:20 PM
Ridiculous
Aug 6, 2006 04:34 PM
Timberman
Jun 1, 2006 10:09 PM
haloman
49
Feb 2, 2005 09:59 AM
