headlight ? input please
i am wanting to upgrade all my lights on my black sport with the cab lights, side markers, head and taillights and i am wanting to know what you all have for input??? i have a buddy with the halos they look nice but i want something that is bright and looks nice and since my truck is black i wanna go with the all black stuff!!! whats the best lights??? pics??? place to get them???
the aftermarket one piece housings did not work in my first hand experience. i tried them first, but then just ended up going with the sport conversion.
if going for looks, then go with the black housings.
if going for functionality - do a sport conversion with upgraded harness.
want the best of both worlds - do the sport conversion and then take the new housings to a tint shop prior to installing. or use black lens paint with a light coat. not sure of the legality though - i'll leave that up to you . . .
i was unhappy with the 'aftermarket ebay' and similar lights/housings. but others have been more than pleased.
oh wait - i see you have sport. in that case - maybe just upgrade the current harness and add a relayed harness in its place.
Id just tint all my marker and tailights, if you can use a spray gun some clear coat and a lil black base coat dumped in it works great. Just sand down every inch of the light with 1500 grit, and make sure you spray everything at the same time with the same amount of coats. It looks kick *** on dark colored cars and trucks, I wouldnt put more than 4 coats of it if you mix the clear and base at a 5:1 ratio
DO NOT GET PROJECTOR lights i have them and they suck!!! i can't see anything unless i have the high beams on plus you have to change the wiring on the truck and i got pulled over for the 3 little blue l.e.d.s $110 fine and the cop said he could of also gave me a ticket for the lenses being smoked
you get a benefit yes. but not the same benefit. especially since you can do the sport conversion (which incorporates an upgraded harness) and then add the flosser bulbs on top of it all. when my bulbs burn out - i will be replacing them with high wattage bulbs.
There are good and bad for each person. I hated my one piece lights till I broke the adjustment end cap so I could aim the lights the way I wanted, not just three feet in front of truck. The projection (low beam)lights don't light up the road and ditches like the stock ones do.
Also had the issue of it being wired incorrect from the supplier. A little do it yourself troubleshooting and they work correct. The aftermarket lights look great!
All depends on where you drive as well. My country roads are a little hairy when driving with low beam, thank the good lord for a good set of driving/fog lights!
mtdoragary
Nov 7, 2013 08:31 AM
Joe Diesel
Nov 12, 2007 08:59 AM
jlipskoc
Oct 24, 2005 01:16 PM
brassbuldog
Oct 25, 2002 08:34 PM
