Headlight harness
Old Jul 13, 2010 | 09:56 PM
Silver R/T's Avatar
Headlight harness
So is this they key to brighter headlights on our trucks?
http://www.lmctruck.com/icatalog/de/full.aspx?Page=46
I've been thinking about getting this part but not sure if its worth the money. Anyone else install one of these?
Old Jul 14, 2010 | 01:47 AM
Ed ke6bnl's Avatar
I need to get that kit, will make a little brighter but will best of all save your head light switch from failure ED
Old Jul 14, 2010 | 05:52 AM
CarlJensen's Avatar
Had one in mine since it was a year old. Saves the headlight switch for you and gives better light. Easy install, well worth the money!
Old Jul 14, 2010 | 09:22 AM
blackimpala's Avatar
The relays will brighten the lights but not much, the real benefit is longer life for the headlight switch.
Floyd
Old Jul 14, 2010 | 10:58 AM
Midnite's Avatar
Did you guys pull the batteries to get the stock connectors off the back of the headlight housings?
Old Jul 14, 2010 | 11:05 AM
Doj Dewd's Avatar
you are semi-correct. the idea of that particular harness is great - but the build quality is not the greatest. if you can solder or want to learn how, then i would suggest building your own with larger wire and better relays . . .
you can buy a kit from here: http://www.danielsternlighting.com/p.../products.html (# RIK-RAM)
or you can buy a well built harness from here: http://suvlights.com/product_info.php?products_id=112
i had the LMC harness at one time - and it worked well for the time i had it, but i could tell it was built poorly the minute it arrived. i have since done a sport light conversion and built my own harness properly with good compnents.
Old Jul 14, 2010 | 11:06 AM
Doj Dewd's Avatar
no. it's a tight fit, but with enough trial and error you will get them off. a smaller set of hands would be great . . . i also used a mini slot screwdriver to release the tabs and then pushed forward slightly instead of doing all the work with your fingers.
mtdoragary
Nov 7, 2013 08:31 AM
evan3000
Jan 6, 2009 12:32 PM
hopak
Apr 3, 2007 12:08 PM
jlipskoc
Oct 24, 2005 01:16 PM
winner172
Aug 19, 2005 08:22 AM
