Head Studs in!!
Old May 16, 2004 | 11:28 PM
joefarmer's Avatar
Thumbs up Head Studs in!!
Well, DonM-provided head studs are in!! Here's quick photo documentary:
Full box of studs:
The actual stud:
The stud in the hole:
The 5mm allen driver is a MUST. I broke 2 cheap t-handle wrenches on the first stud and had to give up until I ran to Sears.
The completed head stud:
The results? On the test drive, I caught a 944 Porsche (multiple times) running the same combination as when I blew the head gasket last month running stock head bolts. The Porsche driver was friendly and gave me a . I just smiled and waved. The End.
brandon.
Oh yeah, a HUGE THANK YOU TO DonM!!!
Old May 16, 2004 | 11:34 PM
powerwagon440's Avatar
awesome!!!!!!!!!!!!!!!!!!!!
Old May 17, 2004 | 02:28 AM
PourinDiesel's Avatar
Joe,
From what it looks like, you installed the studs with the head on the engine.
Did you have to tap anything or was this just a one by one replacement?
--Justin
Old May 17, 2004 | 06:00 AM
Timinva's Avatar
DTR Advertiser
Brandon, I did mine yesterday also. Royal PIA on the rear ones. Most of mine went in by hand, just used the allen to hold them steady when I put the initial load on them. Are you retorqueing them after a couple heat cycles? Tim
Old May 17, 2004 | 03:14 PM
joefarmer's Avatar
Justin, I've cleaned all those holes twice in 3500 miles now, I didn't think they needed it, so I replaced them one by one. I think the installation oil in the holes from last time made it harder to thread mine in.
Tim, I didn't have a problem with the rear ones except that I got tired of kneeling on the bumper putting them in. I retorqued after about an hour of heat cycles. I plan on retorquing again before muncie & methanol. The retorque is easy since only the valve cover and intake rockers have to come out. Just the retorque took about 45 minutes.
brandon.
Old May 17, 2004 | 03:51 PM
csutton7's Avatar
joefarmer--what boost #'s did you see while playin' with the porsche---chris
Old May 17, 2004 | 11:26 PM
joefarmer's Avatar
Not quite certain on the boost, I've been running a temporary guage since the ISSPRO's have been out of stock for awhile now. I normally see 62-65 on the street now. I still have a bunch of tuning to finish up but I haven't found a dyno that will hold me around here. I'm going over to a shop on lunch tomorrow to find out if I can run there. The last shop wanted $80/hr but couldn't handle over a 1000 ft/lbs torque. Wussy import dyno.
brandon.
12valvetom
Nov 27, 2009 11:37 PM
dieselboy59
Jan 30, 2009 03:57 PM
smokewagon
Aug 8, 2008 09:54 PM
MikeThomas
May 11, 2008 11:39 AM
jmccart
21
May 14, 2007 11:47 AM
