Head pres.
Old Nov 18, 2006 | 07:32 PM
clutch1's Avatar
Head pres.
Out of curiosity, by how much do each of these increase cyl. pres.?
Water/Meth
Advance timing
Nitrous
Old Nov 19, 2006 | 06:31 AM
JD730's Avatar
I can't put a number on it, but advancing the timing too far all by itself is enough to kill a head gasket.
Old Nov 19, 2006 | 08:37 AM
clutch1's Avatar
I realize they all increase head psi. which one does the most.
Old Nov 19, 2006 | 09:11 AM
Tiger Rag's Avatar
As I understand it Water/Meth increases drive pressures more than nitrous. I read this in a post by Don M where he said he'd rather someone run nitrous and a lot of it rather than run water/meth. I think the reason was that the meth detonates in the cylinder - basically a fuel where nitrous does not detonate, it just cools the mix and allows for more efficient burning of your fuel mixture. Feel free to correct me if I am wrong, but this is how I understood it. I don't know how timing affects your drive pressures, I'd guess that it would, but that water/meth may contribute more to a failed head gasket than the other 2.
Old Nov 19, 2006 | 09:18 AM
Tiger Rag's Avatar
Here, I found it:
https://www.dieseltruckresource.com/...t=head+nitrous (it was a post about head studs)
Crank them down to 125 ft lbs. They are just fine at that level.
I know I am going to get reamed by some on this subject, but I have seen way too many gaskets fail with methanol systems installed. Water and a very small amount of meth might be ok, but many guys are blowing their gaskets on Diesel only. Some can be traced back to poor machine work, poor installation, and the inherent troubles with the 24 valve cylinder head VS the 12 valve design, but the methanol seems to be causing a detonation problem or a high peak pressure spike before or very near TDC.
The systems are just asking for long term reliability issues, IMO.
I would rather see you run Nitrous. Even lots of Nitrous. At least you dont get any detonation. No engine or gasketing system can take detonation for long. With a spark engine and meth/water you can get away with it. The cylinder temps are not high enough in most cases to pre-ignite the methanol. Unlike a Diesel that can have a 600 degree cylinder temp long before TDC.
Don~
Chrisreyn
Jan 27, 2006 01:39 AM
O.fO.shO
Dec 14, 2005 08:32 PM
CTD_Neil
Mar 22, 2005 03:24 PM
Barry Smith
Nov 14, 2004 09:56 PM
Hoss
Oct 1, 2003 02:10 PM
