he351ve install
he351ve install
well the hy35 just wasn't cutting anymore. decided to go with a holset he351ve. using Fleece Performances vgt controller to control the veins. also putting on a 4" downpipe, an ATS 3-piece manifold and magnaflow 30" muffler.
veins closed
veins open
had to use and adaptor to make it fit on a t3 flange
didn't like the 90deg coming off the turbo. so we changed it up a little. dont mind the ugly valve cover. it was taken off today(adjusted valves) and cleaned up.
also got rid of the silencer ring
veins closed
veins open
sounds cool if i find one cheap in the future ill get one and mess around with one. i wouldnt want it stick up that far almost to the hood.as far is the 90 bend it dont bother me looks kinda wierd with it going downward and all welded up bu if it works it works lol ..thumbs up good build!
I think that would be one hot 500hp, at least on a 12v like mine. Up to about what 'feels' like 325-350 RWHP on my truck, it cools awesome. Past that fueling level, I can bury the pyro and the drive pressure gauge with the vanes wide open in 3rd gear. It's still only a 60mm comp wheel after all.
i am getting a ve geared up for mine also.. so far i plugged the stock mounting holes and will be re drilling to the T3 flange soon.. then its just a matter of finding time to stick it on.. i am going to use a wastegate controller, drive pressure and an adjustable spring for the vanes..
