This Has Me Stumped! Wrap Your Brain Around Ths Please
Old Mar 2, 2008 | 10:48 PM
vzdude's Avatar
DTR's 'Go to Guy'
Voltage regulator is in the PCM. Start with the basics. Check batteries. Load test alt - can be done on the truck. The check for codes.....PCM controls the output of the alt.
Old Mar 2, 2008 | 10:54 PM
bridleman's Avatar
Thanks I will be doing this first thing AM!
Old Mar 3, 2008 | 06:39 AM
Common's Avatar
This same thing happened to me.
Check the connections on your grid heaters for ANY play at all.
I was so freakin' happy when I finally found the gremlin.
Old Mar 3, 2008 | 09:27 PM
bridleman's Avatar
I had the truck checked today and it turned out that my alternator is shot! Thank you guys for all the good imput!!
Chris
Old Mar 3, 2008 | 09:35 PM
Mike D's Avatar
Chris, Check out http://www.mean-green.com/products/alternator.html for a replacement.
Old Mar 3, 2008 | 09:54 PM
bridleman's Avatar
shoot if I wasn't in need of one like right now that would have been the way to go as is I bought one from NAPA for $178. I'm sure it will quit me in a few weeks knowing my luck lately
I sent you a PM
Old Mar 3, 2008 | 10:34 PM
Dave Miller's Avatar
Originally Posted by clinton81
Your alt has an internal Voltage regulator wich may also be going out I would have it tested
I don't believe there is any charing function in the alternator. The charging is supplied by the PCM or ECM (on my 97 its just a PCM...not sure what your ECM does tho). The alternator just has windings and the diode rectifiers.
This is why most auto parts shops that test your alternator say the regulator in your alternator is not functioning...duh...there is none. Be carefull of the average parts guys mis-diagnosing your alternator as bad.
Old Mar 3, 2008 | 10:53 PM
bridleman's Avatar
so how would I know if it is a pcm or ecm??
Old Mar 4, 2008 | 08:12 PM
bridleman's Avatar
Hey Dave Miller............... I decided to check further into what you were saying about the ECM and what I found out agrees with you, there is no regulator in the alternator the ECM controls that so after talking with some electrical shops they all said that I should recheck the Bats. and put a load test to it since most of the "part store gurus" only check voltage and low and behold one of the bats. under load was shot. put a new B\bat. in and everything is working good again.
So thanks Dave you saved me $178 on a alternator and $700+ on a ECM
If you are ever up in Montana check me up and I'll buy you a beer!!
jlipskoc
Mar 9, 2011 06:13 AM
sluggo42
Feb 13, 2007 08:45 AM
Chrisreyn
Dec 6, 2006 03:41 PM
Fronty Owner
May 31, 2006 06:14 AM
Shovelhead
Mar 24, 2006 08:37 PM
