Has anyone used this
Old Nov 1, 2004 | 02:38 AM
shawn085's Avatar
Cool Has anyone used this
Has anyone used this air filter? Looks like it uses cold air but is huge and has a built in heat shield. http://intenseperformance.com/ Look at the web site photo's It is for a GAS engine but it should work.
Old Nov 7, 2004 | 02:55 PM
Cummins Freak's Avatar
if your just using the filter i cant see why they would be any different maybe only a little smaller but you need to make sure the rubber end and make sure it will fit on the tube that connects to the turbo
Old Nov 7, 2004 | 07:09 PM
masonic-dodge's Avatar
shawn
You can go to the S+B filter website and get more info and all the sizes they make and also you will find them to be alot cheaper. You will also need to use some kind of pipe to mate the filter to the turbo inlet hose. Both the filter and the turbo inlet hose are made to go clamp around something.
CRIS.
Oilguy
Jan 22, 2007 07:37 AM
yelloz28
14
Oct 15, 2006 01:07 PM
hump
Jul 15, 2006 06:57 PM
Kauaitransport
Oct 8, 2005 12:15 PM
