Guess the secret squirrel bomb =P
Old 10-20-2006, 01:14 PM
Ph4tty's Avatar
You only need one
Blackdiesel and Getblown want one but they don't know it yet =P
Its round
They claim hp increases on bombed motors but some have not seen gains
Drugs are bad m'kay
I can't give much more info without giving it away. I'll spill the beans when I return from Fall Brawl
Old 10-20-2006, 01:43 PM
SuperDave4x4's Avatar
A down pipe.....
Old 10-20-2006, 02:48 PM
BigBlue's Avatar
It's a TAG ain't it.
Old 10-20-2006, 02:53 PM
zukgod1's Avatar
I'll second that one, it's gotta be a TAG.
dan
Old 10-20-2006, 03:22 PM
Registered
blackdiesel's Avatar
I KNOW I KNOW!!
A TORNADO
Old 10-20-2006, 04:44 PM
Tiger Rag's Avatar
cam? its round from the end?
Old 10-20-2006, 04:58 PM
Ph4tty's Avatar
Cylinder shaped and makes it idle so smooth. I've said too much
Why would BD and GB want them,....hmmm,....
This is too much fun
Old 10-20-2006, 05:24 PM
Charlie8301's Avatar
fluid dampener?
Old 10-20-2006, 06:15 PM
Tiger Rag's Avatar
A bottle of the squeeze is round and cylinder shaped.....but no denying the hp addition there though.....
Aries pistons?
Old 10-20-2006, 06:23 PM
dieselfan's Avatar
i think it is a cam also.
dieselfan
Old 10-20-2006, 06:33 PM
Registered
i dont think so, he said that GB and I want one, but we dont know it yet. And check out my sig, i want a cam!
Old 10-20-2006, 06:41 PM
Turbinator's Avatar
Originally Posted by Charlie8301
fluid dampener?
I think its a fluidampr, too , because he said it makes it idle smooth and theyre also supposed to help with the DD clutches which Ph4tty, GB, & BD all have
CTD2001's Avatar
i am guessing a cam or fluid dampener, the cam does make it idle nice and smooth
Old 10-20-2006, 06:47 PM
Registered
ya that would make sence, because a fluid dampner is cylinder shaped..... humm yall might be on to something
however, it still could be a tornado
Old 10-20-2006, 06:51 PM
Registered
Performance Diesel dampers offer the best protection against torsional vibrations. Performance tuned or stock, your diesel engine will run more efficiently with a viscous Fluidampr® installed.
Torsional Vibrations or harmonics can destroy crankshafts and bearings. These vibrations rob horsepower and torque from the engine. Stock dampers utilize rubber or elastomer to control torsional vibrations. The rubbery material not only breaks down over time, but limits the capabilities for the damper. Fluidampr® uses a viscous silicone fluid, internal inertia ring and a laser sealed housing. Our precision machined assembly is the most effective way to control torsional twisting.
Fluidampr® has tested on both stock and performance tuned diesel pick-ups. Dyno tests have shown consistent increases in horsepower and torque in the three major manufacturers.
thats what it is. it at pdw its like 380 bucks and gave a 6 hp increase on a mildly bombed truck
Quick Reply: Guess the secret squirrel bomb =P
