Guage readings
Old Feb 5, 2004 | 06:03 PM
Lil Red's Avatar
Guage readings
I'm pretty sure this has already been posted but I guess I'm not typin in the right search. My guages are bein installed right now and I was wonderin what the readings would be for the boost, egt, and tranny. Just wantin to make sure of the numbers.
Thanks.
Old Feb 5, 2004 | 06:08 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Try here:
https://www.dieseltruckresource.com/...gauge+readings
Did a search for "Normal Guage Readings" and got several hits.
This one looks to be the most relevant.
Old Feb 5, 2004 | 06:43 PM
infidel's Avatar
If your '94 is stock boost should read 15-18 psi max, egts about 600-800° while cruising the flat empty and the trans around 175°. Cruising the flats boost will be about 3-6 psi.
Old Feb 6, 2004 | 12:18 PM
Lil Red's Avatar
Thanks for the info guys. I just got my truck back and took it for a test drive. My boost when it kicks in to overdrive goes to about 20, my egts go up to about 1000 F and settle to 800 F, and my tranny has gone above 150 F. These will change wants I start more bombing correct.
jrs_dodge_diesel
14
Dec 15, 2006 07:59 AM
napa 600
Oct 6, 2005 09:15 AM
csramsey640
Sep 16, 2005 01:10 PM
xp8103
29
May 21, 2005 12:19 PM
flyingd
Feb 28, 2004 01:31 PM
