gauge question
Old Apr 14, 2008 | 02:48 PM
flatbed beast's Avatar
gauge question
Does it take a special wire to go frow the transmission sensor to the gauge
Old Apr 14, 2008 | 02:53 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
It should be just a wire. 22 gauge or so is sufficient. What brand of gauge are we speaking of tho? Some have two wires going to the probe and some only have one wire going to the probe.
Old Apr 14, 2008 | 04:55 PM
It is a auto meter and it only has one wire going to it.
Old Apr 14, 2008 | 04:58 PM
JPR Ram's Avatar
Then 22 gauge wire is more then enough...........
Old Apr 14, 2008 | 09:43 PM
Another question i am having trouble hooking up my boost gauge. I tried a plug on the side of the engine today and didn't get anything. Where do you all connect you sender? And with my pyro do i need to go before turbo or after turbo with the sensor.
Old Apr 14, 2008 | 09:49 PM
wurkenman's Avatar
Boost has to go in the intake. right after the intake horn would be the best. The pyro should go right before the turbo.
Old Apr 14, 2008 | 09:58 PM
ok thanks. can i tap into the intake horn?
Old Apr 14, 2008 | 10:02 PM
JPR Ram's Avatar
Yes you can. Or you can just buy a boost bolt and replace one of your intake manifold bolts.
Old Apr 14, 2008 | 10:09 PM
Lil Dog's Avatar
On the BTA 12V engines, there is a 1/8 NPT plug just ahead of the elbow for the tubing going to the AFC. That plug will give you boost pressure reading. Boost bolt is for 24V applications. You don't need to tap the intake horn.
As far as the pyro, PDR instructions are good for installation.
TST/PDR Pyro Install
TST Boost gauge install
Old Apr 14, 2008 | 10:21 PM
DL1221's Avatar
Yup, exactly what he said ^^^^^^.
Oh by the way, you won't see any boost at idle, you have to drive around and let the engine make power, then you'll see some boost.
Old Apr 15, 2008 | 07:55 AM
I put the sender in that plug that the plans that lil dog said to do and i showed no boost. I didnt drive around but at an idle i reved it up. Is my problem that i didn't drive around? also got any ideas how to get the metal shavings out of the exahust manifold? thanks sam.
Old Apr 15, 2008 | 08:42 AM
CODODGE2500MAN's Avatar
I'd drive around....
I'm not possative on the 12v, but i don't really get any measurable boost just by reving it a little.
There's a reason they call it a test drive.....just take the truck over trailridge road and it'll let you know if you've got boost!
As for the metal shavings, I'd just take the horn off and then drill....shouldn't be too hard. use some compressed air if it's off the block.
Old Apr 15, 2008 | 09:00 AM
yeah i dont know if i have big enough tires to go over trailridge right now.
What about getting the shavings out of the exahust mainfold?
Old Apr 15, 2008 | 09:12 AM
That's for sure.....I used to live in Grand Lake and I know it won't make it over there now, (the jeep on 37's wouldn't either) but spinning all 4 for a little should build some boost.....might want to take another truck to pull you out though.
As for getting the shavings out, I've never done it (I had mine installed...) but maybe a slow speed drill and then a heavy duty magnet...
I'm sure others will chime in on how they did it.........
Old Apr 15, 2008 | 12:23 PM
JPR Ram's Avatar
I wouldn't drill and tap a hole into the intake with it on. You gotta take it off, drill and tap, clean and then re-mount the intake.
