gauge lighting
gauge lighting
finally have my fuel gauge ready to be put on its all set up with all the fittings and lines and pod to hold it---which is junk to fit an isspro gauge in, i did more cutting and chopping than i wanted to. ANYWAYS to power the gauge im figuring i can tap into the switch for the lights, pulled the switch and theres a mess of wires there. Which can i tap into to get power when the running lights and headlights are switched on. or i read it goes into the dimmer. any thoughts. thank you
Not sure if your '01 is the same, but try this:
https://www.dieseltruckresource.com/...t=gauge+lights
HighTen
Mar 5, 2005 11:10 PM
SuperGewl
Jul 17, 2004 12:34 PM
