fuel tank quick connect
Old Apr 3, 2005 | 12:16 AM
chucktownsend5's Avatar
Question fuel tank quick connect
Does anyone know if you can get a fitting that will allow you to use the stock quick connect fitting on top of the fuel tank to connect to a larger fuel line? I want to replace my stock fuel lines with larger 8An lines from the fuel tank all the way to the injector pump. thanks.
Old Apr 3, 2005 | 12:22 AM
Haulin_in_Dixie's Avatar
I would recommend eliminating the quick disconnect as they tend to leak air. 3/8 line will slip over the end that comes from the tank and a clamp will hold it securely.
Old Apr 3, 2005 | 07:53 AM
Geico266's Avatar
I agree, just get rid of the quick connect and use two hose clamps in its place.
dieselfan
13
Mar 20, 2018 08:58 PM
robby t
Dec 16, 2013 09:22 PM
ripping r
Jan 5, 2010 06:58 PM
RHC
Oct 26, 2009 11:17 AM
Falcon2005
Dec 13, 2004 10:49 PM
