Fuel System Issues
Old Aug 27, 2008 | 10:19 AM
mykal41's Avatar
Fuel System Issues
We have a 2001 with a glacier 392 kit. The other day the fuel cap was hissing, So i pulled it off and the tank was full of pressure. This fuel system was installed 9 months ago and has been trouble free.
Does anyone know what would cause this. With the cap of you can se the vapors escaping the tank.
I checked all the return lines and tank vents.
Old Aug 27, 2008 | 12:59 PM
scottsjeeprolet's Avatar
Last time this happened it was a loose hold down on one of the injectors.
Did you change your injectors lately? Something is pressurizing the fuel system. Could be a combustion chamber leak somewhere. Hows the oil level and smell? Doesn't smell like diesel does it? How's the anti freeze level and look of it. Could also be a head gasket.
Old Aug 27, 2008 | 07:09 PM
mykal41's Avatar
No anti freeze or fuel in the oil... But we did just install a set of injectors....I will check the hold downs in the am...... Thanks for the input.......
Herr Diesel
May 13, 2024 05:44 PM
RiverRat2
Oct 15, 2019 10:59 AM
One Way
Dec 19, 2010 04:00 PM
westspeed
Nov 10, 2010 07:52 AM
sandpuller2004
Sep 29, 2005 01:01 PM
