fuel pumps
Old Jan 8, 2007 | 12:10 AM
chuck85's Avatar
fuel pumps
if i ran a holley blue where would be a good place to purchase one for my dodge and how do you wire it to the truck
Old Jan 8, 2007 | 08:10 AM
riversidediesel's Avatar
You could get it from Jegs or Summit Performance. They're about $100, but just depends on where you go. When I wired mine I ran the wire through the frame and up to the ECM and tapped into that conjunction with the stock in-tank pump that I have. So whenever you turn the key on, both pumps are working simultaneously.
Old Jan 8, 2007 | 06:04 PM
dsl kicks gas's Avatar
i've not got mine put on yet, but i'm etiher gonna use the stock lift pump harness or tie in a hot acc. spot in the fues box. you can get a procomp black(same as holley blue) off of ebay for right at $75 with shipping.
are you planing to run the stock pump with the blue or by it's self???
Old Jan 8, 2007 | 06:40 PM
John_P's Avatar
chuck85:
You can also purchase the Holley Pumps at any "Advance Auto Parts" Store.
They are about the same price as they are in "Jegs" or "Summit" and they give you a full one (1) year warranty on them.
John_P
Old Jan 8, 2007 | 08:46 PM
merrillr4's Avatar
So I have a favor to ask, could I get a picture or some detailed instructions for the wire you tapped for the Holley Blue to turn on? You could call it "Installing Holley Blue for Dummies"
Old Jan 8, 2007 | 08:55 PM
dieselfan's Avatar
mine is stuck in my fuse box, when the key is on, its on. if i want it off for some reason, i can just pull it from the connector.
youll know if its the wrong one, if it keeps running when you shut the key.
Old Jan 8, 2007 | 09:05 PM
piperca's Avatar
You should install a relay harness from your battery to the pump, with a trigger to fire the pump. Here's a diagram:
Some people use a Hobbs switch to power on when the oil pressure is up, this helps with the hard start problem when running too much pressure.
Old Jan 8, 2007 | 09:10 PM
merrillr4's Avatar
Awesome!! I do have a relay set up, now I just need to hook up the trigger switch to the hot wire and I am good to go, right? This will make the Holley Blue switch one once the truck starts?!? Thanks
Old Jan 8, 2007 | 09:34 PM
will you be running the blue by it's self or with stock lp. if it's by its self just hook it up to a hot (key on) power source.
Old Jan 8, 2007 | 09:50 PM
merrillr4's Avatar
I do have the in tank pump installed, and I have a Holley Blue on the frame. The trucks suffers from hard starts when the grid heater cycles for some time during cold weather starts. I want to find the appropriate wire to tap to switch the pump on when the truck actually starts. I do have a relay set up off of the battery and the trigger switch closes as soon as the key is in. It runs into the fuse box in the cab, I think #17 fuse spot. What should I do different for the switch wire?
JJK98CTD
Mar 29, 2009 10:45 AM
Ilikebikes
Dec 11, 2006 10:13 PM
Watch This
Oct 26, 2003 07:22 PM
May 31, 2003 03:28 PM
scottrod
Oct 20, 2002 06:42 PM
