fuel pressure regulators
Old Jan 30, 2005 | 04:38 AM
2500CTD's Avatar
After all the reading on fuel systems I did. What about mounting a fuel pressure reg right at the input to the vp44? That way consistant fuel pressure all the time??? Or is this a way to trash the IP?
Old Jan 30, 2005 | 06:48 AM
Kyle Graham's Avatar
Are you getting too much fuel I don't understand why you will need it. Most dont have enough fuel to the vp44 so they add a pusher pump or a whole new pump
Old Jan 31, 2005 | 04:07 AM
2500CTD's Avatar
No just thinking of upgrading the fuel system. Instead of having the pressure rise at idle, a reg would keep pressure constant, well as long as the pump can keep the demand up at WOT. I'm looking at a pusher pump. I read in the service manual the valve open at about 14psi in the VP44, so if I kept 12psi all the time there??? Also with more than need flow, the VP would cool a little better. Just trying to research before I buy anything
93 high hopes
Oct 22, 2012 03:47 PM
dodgeguy71
17
Jan 19, 2012 12:52 AM
capt.Ron
Nov 12, 2009 08:48 AM
tfarm
Aug 20, 2008 07:21 PM
89dieselkong
May 6, 2007 07:57 PM
