Fuel pressure help
Old Nov 26, 2005 | 08:31 AM
IHMAN75's Avatar
Fuel pressure help
I am looking for a pusher pump or parallel fuel system for my 01 to assist the junk dodge lift pump. Can anyone give me some info on what they've done or would do. I am familiar with the FASS, but wanting to know if there is anything else recommendable out there. thanks a bunch in advance for your help. Shawn
Old Nov 26, 2005 | 08:46 AM
blackdiesel's Avatar
Registered
the way im set up, along with many others on here, is a Holley Blue. its a cheaper, yet effective alternative to the fass.
Old Nov 26, 2005 | 11:01 AM
Big Deezul's Avatar
I went with the BD pusher pump kit. A little more money but it comes with everything you need to do the job (except the tools) very straight forward kit and it works great.
Old Nov 27, 2005 | 06:15 PM
scottsjeeprolet's Avatar
i got the Bully Dog fuel management system from JEGS.com for about $240. i works great 22 psi at idle and 15 @ WOT
Old Nov 27, 2005 | 06:18 PM
eric13's Avatar
I just installed the carter 4601hp back by the tank I am getting 24 at idle and 15 at WOT. I also left the factory pump hooked up
Old Nov 27, 2005 | 06:59 PM
JBlock's Avatar
TRy Vulcan Relocation Kit
Vulcan Performance make a nice relocation kit to the stock pump back by the tank, they also make a wiring kit option for two pumps, it has bigger banjos, 1/2 fuel ines and all the bits and pieves.
Vulcan kit+relocated stocker LP=17psi cruising and no less than 14psi at wot with over 500hp.
http://www.vulcanperformance.com/dieselperfomance.html
dodgeguy71
17
Jan 19, 2012 12:52 AM
MoparRiggan
Jan 5, 2006 11:09 AM
mtl0727
Nov 5, 2005 06:47 PM
darrenG
Jun 28, 2005 07:43 AM
Flatty
Jan 5, 2005 02:50 PM
